CLASH OF THE TITANS IV
PRESENTING FOR WINDOWS 7......
HUD
This is my new Premium Theme for Windows 7 and also my entry for the VC comp Clash of the Titans IV
It's been another great comp at VC and we have had some fresh new talent as well this time round and they have been showing amazing stuff and with some being their first ever themes I am expecting great themes to come in the future.
Check out the Comp here to join in the fun and look at the upcoming themes
The HUD theme extras can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
Features:
HUD Basic Theme
HUD Topshell Theme
HUD Topshell Basic Theme
HUD Icons
HUD Icons
System Clock
Shell32 Control panel images
MAX Glass Cursors
HUD Sound Scheme
System Properties Logo
Getting Started top Pane
Games Menu Preview Pane
And much more!!
I would also like to add a big thanks to submicron [Only registered and activated users can see links. ] for his permission to include one of his latest walls Module -Abyss Lapis- [Only registered and activated users can see links. ]
I would like to say a huge thanks to Lefty and Gor17981 for making some great matching extras, please don't forget to give them some thanks and rep for their amazing contributions
These are the extras Gor17981 has made for [Only registered and activated users can see links. ]
And from Lefty
Rocketdock skins
Desktop Gadgets
Information
HUD Basic Theme
