July 23rd, 2011 07:43 AM #1
How To Correctly Setup Your Ssd And Get The Advertised Read
Ok guys and gals today I am going to show you how to properly setup your SSD and get to the advertised read and write speed of your SSD. I recently purchased two OCZ agility 3 hard drives and took them back due to them not getting even close to the correct read and write speeds. I ended up getting a Crucial M4 but was still not getting the proper speeds so I did some searching and finally figured it out on my own with different information on the net and took the time to put together this tutorial to help out anyone that wants to have lightning fast speeds with their SSD's.
I use AS SSD to benchmark my SSD which can be found here for free:Code:https://www.alex-is.de/PHP/fusion/downloads.php?cat_id=4&download_id=9
In Registry Editor click on HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services and scroll all the way down to the folder called "msahci" and then right click on the icon called "start" in the right hand pane and choose modify.
If you are not familiar with editing the registry you can download this fixit tool from MS:Code:https://support.microsoft.com/kb/922976
Next thing you need to do is reboot your computer and enter the bios and enable "AHCI"
Upon first boot in Windows 7 it will load AHCI drivers for each present drive and then you will need to reboot once more.
After that you will be getting the proper "Read and Write" speeds for you new shiny SSD.
Please see the below to screenshots and check out the 232 point difference in the benchmark.
Also please note that each time you see red as in the picture below that says "pciide - BAD" in anyones benchmark results it means that they have not properly setup their SSD. As you can see by the bottom benchmark it is now stating "msahci - OK" and it is green for good reason.
Before:
After:
wall images not showing correctly
By MOST_WASTED in forum OS & Hardware Help and SupportReplies: 0Last Post: September 15th, 2012, 10:18 AM -
How To Correctly Setup Your Ssd And Get The Advertised Read And Write Speed
By odinlives in forum Setup TutorialsReplies: 21Last Post: March 31st, 2012, 09:39 PM -
How to setup your system correctly - A little Guide
By Taxidriver05 in forum Setup TutorialsReplies: 7Last Post: October 30th, 2011, 11:11 PM -
Fix: Windows Ribbon is not displayed correctly
By razorsedge in forum News & ReviewsReplies: 0Last Post: August 30th, 2010, 07:20 PM
