User Tag List
Results 1 to 2 of 2
    imported_merseed is offline
    Apr 2010
    7
    Post Thanks / Like
    Help change Start menu
    Hello Please help to change the width of the "Start Menu"
    Tell me how to reduce the width of the Start menu?
    Reply With Quote Reply With Quote Share/Bookmark
    Mr GRiM is offline
    Bringer of Death
    Aug 2009
    Cairns, FNQ, Australia
    35
    4,172
    Post Thanks / Like
    6 Post(s)
    144 Thread(s)
    Re: Help change Start menu
    Quote Originally Posted by imported_merseed View Post
    Well first of all it's not a problem with the width I beleive this must be a problem with the language type you have, for some reason it will not shorten the full name like on mine for instance Device and Printers is shortened to Device and Print...
    There is a way to fix it though but it will require you to set the expanded default panel size to the same as the normal values, if your using the updated classmaps form the base style resources I posted then the location for the default panel size should be in Start Menu > Panels > Aero > Top > Places List > Places List > DefaultPanelSize:Rect copy that value to the one in Start Menu > Panels > Aero > Top > Places List > Places List Extended and do the same for Start Menu > Panels > Aero > Top > Places List > Logoff, on my hud theme you may also want to export the images for those locations and import them in to the extended locations, also copy any sizing margins as well.
  1. Help Change Start Menu Font?
    By BigBoss0327 in forum Start Menu
    Last Post: 07-12-2011, 04:23 AM
