Page 1 of 2 12 LastLast
Results 1 to 8 of 16
Thread: 7tsp "can't find pack.ini" FIX Share
    YourNumbr1Fan is offline
    Ever visit uranus I'm there now lol
    Jul 2011
    None
    994
    11 Post(s)
    339 Thread(s)
    I, for months, have been stumped as to why I was getting errors with 7tsp....
    Kept getting "pack.ini not found" and "no .res files in resources folder"; I sent messages to Mark (Mr Grim), and he seemed stumped too.
    Last night I saw this post on the XPtsp Support Board!
    [Only registered and activated users can see links. ]The user "Tidus" had the fix! The 7tsp proggy didn't recognize the "&" symbol in my Admin account name on my pc! My admin. account on my pc used to be "J&Y" ..... So, after re-formatting last night, and setting up the admin. account as "YN1F" , I (hallelujah!) can now use 7tsp flawlessly!!! Isn't that a gas, man!?
    So, anyone having similar problems with 7tsp should read the XPtsp Support Board post linked above!
    Ravzz is offline
    Oct 2011
    9
    There is no special symbol in my username then also this error keeps coming...plz suggest me sumthing
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,764
    21 Post(s)
    296 Thread(s)
    check the posting above for any of the symbols. plus make sure when you zip the files they are in 7zip format. also make sure the .ini is not inside a folder when you zip the pack or it will not find it
    Hellcat is offline
    Elite
    May 2010
    Hungary
    1,662
    4 Post(s)
    365 Thread(s)
    Cool
    very good info, thank you Jimmy
    question, I would like to remove of a 7tsp one file of zip,
    because I do not want upload, that I can solve it?
    thank you help
    Ravzz is offline
    Oct 2011
    9
    Hey thanks BigV. I will try what u have suggested....
    Ravzz is offline
    Oct 2011
    9
    ok So checked the user and computer name...no issues with it. Turned of UAC. checked the format of downloaded file...it is 7z. But still that error keeps on coming. Is it an issue with my 7tsp......Also i was thinking that can anyone suggest me how to change a .dll.res files which are present in package to siple .dll files so that i can install them manually.......
    Actually i wanted to use Mr.GriM's HUD theme icons.....but i dont have .dll files for that......are they present on the site,if yes plz suggest me the link..........
    Thanks in Advance.
  7. #7
    Ravzz is offline
    Oct 2011
    9
    Hey i havent recieved any replies on this post ....plzplzplz suggest me something........
  8. #8
    Big V is offline
    A Supreme God
    Feb 2010
    2,764
    21 Post(s)
    296 Thread(s)
    Quote Originally Posted by Ravzz View Post
    Thanks in Advance.
    [Only registered and activated users can see links. ] have you looked at this vid if you are still having issue you can do the files manually with restorator and here is a tut for that [Only registered and activated users can see links. ]. Just extract the 7 tsp pack to a folder on your desktop each dll,cpl,etc that is in the pack you will need to find the matching file in your c/windows/system32 folder. Once you locate the the corresponding file you want to edit take ownership of it first. Then copy it to your desktop. Now you will need to open that file and the res file from the pack using restorator and drag the image from the pack into the file from your system 32. The res files should already have the proper names or numbers require to match the image you are replacing. Once you have all the images you want dragged over hit save and close restorator. Now go back to c/windows/system32 and relocate this file again and rename that file adding .bak or .old (timedate.cpl.bak) to end of the file extension. that will be your original file and backup if you ever need to restore it. All you will have to do is change the name back and delete the new file if you need to do a restore. Now that you have the original file renamed you can go back to your desktop to the file we just edited and copy it. Then paste it into the system32 folder and your done. Now when you look at your system 32 folder you should see two files of the .dll we just edited. The new file we created will look like the original file. And the original that we left in the system32 folder will have an extra extension added to the end of the name .bak
  1. 7tsp "can't find pack.7zip/rar" FIX
    By றѳѳղղįqվદ in forum Theme & Extras Setup Tutorials
    Last Post: 08-18-2013, 10:44 AM
  2. Apple Jokes About "Sea Lion"; Calls Next OS X "Mavericks"
    Last Post: 06-10-2013, 11:47 PM
  3. """ X-FORCE""" COMMING SOON
    By deviantdon in forum General Customization
    Last Post: 11-08-2012, 01:10 PM
  4. "" alienware 3000 ""
    Last Post: 10-27-2012, 02:27 PM
  5. Replies: 9
    Last Post: 02-28-2010, 03:41 PM
