PROUDLY PRESENTING FOR WINDOWS 7......
The HUD RED theme is finally here and there are many new changes to the theme as well as a new red icon set to match, this theme is not just a simple recoulour, allot of the graphics were tweaked and redone to ensure that everything blended together to make a truly stunning theme, the same goes for the icons, every icon has been recreated and tweaked so that the reds are red and allot of the icons were designed again from scratch.
The HUD RED theme extras can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
Features:
HUD RED Theme
HUD RED Basic Theme
HUD RED Topshell Theme
HUD RED Topshell Basic Theme
HUD RED Icons
System Clock
Shell32 Control panel images
EZMAX Cursors
HUD Sound Scheme
System Properties Logo
Getting Started top Pane
Games Menu Preview Pane
And much more!!
[SIZE=5]I would also like to add a big thanks to [Only registered and activated users can see links. ] for his permission to include 3 of his great wallpapers Injected Lapis [Only registered and activated users can see links. ][Only registered and activated users can see links. ], [Only registered and activated users can see links. ] [Only registered and activated users can see links. ] and [Only registered and activated users can see links. ][Only registered and activated users can see links. ]
Download The HUD Red Premium Theme
Mirror
Additional Theme Extras
ObjectDock Tabbed Docks
Alternative Tabbed Docks By Gor
Alternative Tabbed Docks 3 By Gor
Winstep Xtreme Docks By Gor
AIMP 3 Skin By Gor
Information
HUD RED Theme
formidable theme, Beautiful harmony all details, great work, thank you mark
