Thread: HUD RED
September 24th, 2011 12:56 AM #1
HUD RED
The HUD RED theme is finally here and there are many new changes to the theme as well as a new red icon set to match, this theme is not just a simple recoulour, allot of the graphics were tweaked and redone to ensure that everything blended together to make a truly stunning theme, the same goes for the icons, every icon has been recreated and tweaked so that the reds are red and allot of the icons were designed again from scratch.
The HUD RED theme extras can be installed or uninstalled using 7tsp found here
Features:
HUD RED Theme
HUD RED Basic Theme
HUD RED Topshell Theme
HUD RED Topshell Basic Theme
HUD RED Icons
System Clock
Shell32 Control panel images
EZMAX Cursors
HUD Sound Scheme
System Properties Logo
Getting Started top Pane
Games Menu Preview Pane
And much more!!
[SIZE=5]I would also like to add a big thanks to submicron for his permission to include 3 of his great wallpapers Injected Lapis Injected Lapis coloured Red, Blood Flow and BioHazard Reflective
Download The HUD Red Premium Theme
HUD_RED_Theme_Pack_x64-v10.exe
HUD_RED_Theme_Pack_x86-v10.exe
Mirror
Additional Theme Extras
ObjectDock Tabbed Docks
Alternative Tabbed Docks By Gor
Alternative Tabbed Docks 3 By Gor
Winstep Xtreme Docks By Gor
AIMP 3 Skin By Gor
InformationVery Important!!!
UxStyle Core
WARNINGIf you install the 7tsp theme extras and find you have lost your sound or if you are using a Creative Sound Card you will need to use Restore on 7tsp and then remove the pack from 7tsp, then open the 7-zip archive and in the resource folder you will see shell32.dll.res, you need to delete that file and then repack the theme pack using 7-Zip again, then load it into 7tsp again and reinstall it.
Post Your Windows 11...
