Page 12 of 13 FirstFirst ... 28910111213 LastLast
Results 89 to 96 of 103
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    34
    3,477
    4 Post(s)
    31 Thread(s)
    HUD RED Premium Windows 7 Theme
    PROUDLY PRESENTING FOR WINDOWS 7......
    The HUD RED theme is finally here and there are many new changes to the theme as well as a new red icon set to match, this theme is not just a simple recoulour, allot of the graphics were tweaked and redone to ensure that everything blended together to make a truly stunning theme, the same goes for the icons, every icon has been recreated and tweaked so that the reds are red and allot of the icons were designed again from scratch.
    The HUD RED theme extras can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
    Features:
    HUD RED Theme
    HUD RED Basic Theme
    HUD RED Topshell Theme
    HUD RED Topshell Basic Theme
    HUD RED Icons
    System Clock
    Shell32 Control panel images
    EZMAX Cursors
    HUD Sound Scheme
    System Properties Logo
    Getting Started top Pane
    Games Menu Preview Pane
    And much more!!
    I would also like to add a big thanks to [Only registered and activated users can see links. ] for his permission to include 3 of his great wallpapers Injected Lapis [Only registered and activated users can see links. ][Only registered and activated users can see links. ], [Only registered and activated users can see links. ] [Only registered and activated users can see links. ] and [Only registered and activated users can see links. ][Only registered and activated users can see links. ]
    Mirror
    Additional Theme Extras
    ObjectDock Tabbed Docks
    Alternative Tabbed Docks By Gor
    Alternative Tabbed Docks 3 By Gor
    Winstep Xtreme Docks By Gor
    AIMP 3 Skin By Gor
    Information
    Very Important!!!
    Licence Agreement: This content is protected by DMCA. (Digital Millennium Copyright Act Protection Services)
    Signature thanks to the awesome [Only registered and activated users can see links. ]
  2. Thanks Letícia® thanked for this post
    Likes Letícia® liked this post
  3. #89
    gr4f1xJuNki3 is offline
    Jul 2011
    30
    Hey Grim! Been a while since I've been here so forgive me if you already did it... Did you make a Auslogics disk defrag , Steam or Calculator Icon to go with this theme yet? That'd be great! Thanks!!
  4. #90
    Dead_already is offline
    Dec 2010
    3
    I know my start button didnt change right away because I had another theme on in tuneup utilities, and have you downloaded the free icon pack? because I think that includes a start button changer and such
  5. #91
    Dec 2010
    3
    Also if anyone could shed some light on how to apply those themes to object dock... I cant seem to figure it out
  6. #92
    Archlight is offline
    Feb 2011
    10
    Hey Mr. Grimm, I'm back again to ask a question on the process of the theme I've installed. You know the Aero Peek program where if you hover your mouse over an item on the taskbar, it will show a mini pop-up preview version?
    For some reason, when I installed the red version of HUD, it's not working. When I go to properties of the taskbar, it does say Aero is selected and I actually can't deselect it...it's greyed out. I'm trying to research online to see if I can find anything to help, but can you shed any light on this? I'm trying to uninstall everything and start over right now.
    When I first installed it, it wasn't working then at one point it was, and I don't recall exactly what I did or when it happened...but I left it alone. Recently I had to do a system restore and that just screwed everything up -.-
    Any help is greatly appreciated.
  7. #93
    rydga7 is offline
    May 2012
    anchorage ak
    5
    Great theme! How do I get the start button to change? I tried to use 7tsp but, when I chose change start button it brought me to my downloads to choose but, the folders are empty...
  8. #94
    Toadyshadow101 is online now
    VC Moderator
    Nov 2011
    In My Command Center (AU)
    1,256
    7 Post(s)
    43 Thread(s)
    Quote Originally Posted by rydga7 View Post
    Did you install theme resource changer if not you need to install it then the start button will show [Only registered and activated users can see links. ]
    Hope That Helps Bud
    Fear Shall Not Be My Enemy, Fear Shall Be My Friend, & Together We Shall Strike Courage In To The Heart Of The Fearful.
    A programmer is only a tool which converts caffeine into code
  9. #95
    rydga7 is offline
    May 2012
    anchorage ak
    5
    indeed i did but, i feel i have done something wrong. the "windows explorer has stopped working" error has appeared. i reset that but, then re-ran 7tsp and it has come back. my windows are gray instead of transparent/black, i do have an icon for the windows button instead of the windows orb but, it is just the windows icon and it says "start". i think i am going to uninstall everything except my hud red purchase and start over unless there are any suggestions. thank you for your help.
  10. #96
    VC Moderator
    Nov 2011
    1,256
    7 Post(s)
    43 Thread(s)
    Hi Bud By Any Chance Have You Patched Your System To Enable Third party themes [Only registered and activated users can see links. ]
  1. HUD Premium Windows 7 Theme
    Last Post: 2 Days Ago, 10:57 AM
