October 30th, 2011 11:51 PM #1
How to Remove Mr GRiM's Themes and 7tsp Packs
OK I get this question a fair bit so I might as well make a tutorial for it, this will explain how to completely remove one of my themes, this does not completely apply to all my themes, mainly since Blade and Zero-G plus all the Premium Themes that use my custom installer.
What does it install with the installer?
1. The first thing my installer does is dump all the contents of the theme into your temp folder
2. Next it adds some registry entries, these entries are for Theme Resource Changer
Code:<REGISTRY> SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}<VALUE><TO>CThemeResourceChangerObject Class SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}<VALUE>AppID<TO>{508AE86B-33BB-4F20-A7F1-7AC86F5DD375} SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32<VALUE>ThreadingModel<TO>Apartment SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32<VALUE><TO>\Program Files\Theme Resource Changer\ThemeResourceChanger.dll SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\ProgID<VALUE><TO>ThemeResourceChanger.CThemeChange.1 SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\Programmable<VALUE><TO> SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\TypeLib<VALUE><TO>{CFA8AF78-B9E2-4C91-8DB7-2314C781E8A4} SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\VersionIndependentProgID<VALUE><TO>ThemeResourceChanger.CThemeChanger SETKEYVALUE:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler<VALUE>{F791A188-699D-4FD4-955A-EB59E89B1907}<TO>Theme Resource Changer CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907} CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\InprocServer32 CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\ProgID CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\Programmable CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F791A188-699D-4FD4-955A-EB59E89B1907}\TypeLib CREATEKEY:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler </REGISTRY>
4. The first thing my Batch file does is create a new Backgrounds folder in C:\Windows\System32\oobe\Info for your login backgrounds and changes some registry entries.
Code:reg add HKLM\Software\Microsoft\Windows\CurrentVersion\Authentication\LogonUI\Background /v OEMBackground /t REG_DWORD /d 1 /f reg add HKLM\SOFTWARE\Policies\Microsoft\Windows\System /v UseOEMBackground /t REG_DWORD /d 1 /f
Code:mkdir %windir%\Resources\Themes\HUD_RED\Backgrounds mkdir %windir%\Resources\Themes\HUD_RED\Cursors\"EZMAX" mkdir %windir%\Resources\Themes\HUD_RED\"explorer.exe" mkdir %windir%\Resources\Themes\HUD_RED\"explorerframe.dll" mkdir %windir%\Resources\Themes\HUD_RED\"imageres.dll" mkdir %windir%\Resources\Themes\HUD_RED\"Sound Scheme" mkdir %windir%\Resources\Themes\HUD_RED\shell\"NormalColor"\"en-US" mkdir %windir%\Resources\Themes\HUD_RED\"Shell32.dll" mkdir %windir%\Resources\Themes\HUD_RED\Fonts
Code:mkdir %SystemDrive%\"Program Files"\"Theme Resource Changer" REM Theme Resource Changer COPY /Y %Temp%\HUD_RED\X64\"ThemeResourceChanger.dll" "%SystemDrive%\Program Files\Theme Resource Changer"
Code:COPY /Y "%Temp%\HUD_RED\HUD_RED\*.*" "%windir%\Resources\Themes\HUD_RED\*.*" COPY /Y "%Temp%\HUD_RED\HUD_RED\Backgrounds\*.*" "%windir%\Resources\Themes\HUD_RED\Backgrounds\*.*" COPY /Y "%Temp%\HUD_RED\HUD_RED\Fonts\*.*" "%windir%\Resources\Themes\HUD_RED\Fonts\*.*" COPY /Y %Temp%\HUD_RED\HUD_RED\Cursors\"EZMAX" %windir%\Resources\Themes\HUD_RED\Cursors\"EZMAX"\*.*
9. Now the batch file will start the fonts.vbs script and this will install the fonts for the theme.
10. Now everything is installed and the theme will be applied.
11. Explorer will restart and all temp files are removed.
Note this is an example from the HUD theme installer, older installers are a little bit different, with my new install batch files the installer will halt at each step and give you the option to install the different parts of the theme.
7tsp Icons and extras Packs
The 7tsp packs patch a number of system files, mainly to add new icons but it can also patch many other things, 7tsp will not replace any of your system files, it is made this way so you can not replace a file with an older version, this will happen if you have a windows update and using older system files, it also doesn't need to know if you are using a x86 OS or a x64 OS, this ensures that chance of user error is greatly reduced.
7tsp will first create a new restore point before making any changes and then will scan the contents of the 7tsp pack and make a backup of each individual file it replaces which are stored in C:\Program Files (x86)\7tsp\backup, these backup files are what it uses to revert any changes.
Now for the Uninstall Tutorial
Uninstalling the 7tsp Pack.
Run 7tsp and select the option to restore modified system files to before 7tsp was used, this will restore all your system files from 7tsp backup folder.
Sometimes this is not enough, say for example you have installed a second 7tsp without doing a restore first, this means that the backup files 7tsp created will be from the previous 7tsp pack you had installed and means you will not have a complete restore.
In this case you will need to use the 7tsp restore option: Restore "all" modified system files to Windows 7 default. This will start a sfc /scannow command and will restore all your system files, this means that if you want to use your custom themes again you will also have to run Universal Theme Patcher again.
Uninstalling the theme.
Go to C:\Windows\Resources\Themes, delete the .theme eg. Zero-G.theme file and the theme's folder eg. Zero-G
Uninstalling Theme resource Changer
Open C:\Program Files and delete the folder called Theme Resource Changer, you may have to move it to the desktop as the file will still be in use but after a restart you can then delete it.
Remove the registry entries by opening the registry editor and search for {F791A188-699D-4FD4-955A-EB59E89B1907} and delete that folder.
Uninstalling the Logon Screen.
To remove the startup screen just delete the backgrounds folder in C:\Windows\System32\oobe\Info and will return to your default one, or you can change it using this program https://www.julien-manici.com/windows...round_changer/
7tsp and iPack ROG Icon Packs for w7 w8 8.1 w10
By ミறѳѳղղįզվદ彡 in forum 7tsp Icon PacksReplies: 0Last Post: June 29th, 2019, 08:34 AM -
By ミறѳѳղղįզվદ彡 in forum iPacks for Win 7Replies: 0Last Post: June 29th, 2019, 08:34 AM -
Help! How do I remove my 7tsp icon packs?
By Kaeldre in forum IconsReplies: 4Last Post: December 10th, 2016, 08:30 PM -
Mozilla to Remove Themes from Firefox
By Shemhamforash in forum General Windows 7 CustomizationReplies: 9Last Post: November 12th, 2015, 12:39 AM -
7tsp packs
By 52bruno in forum Theme RequestsReplies: 1Last Post: March 24th, 2013, 08:25 PM
Wicked been looking for something as nice as this thanks man
RISEN Theme pack for...
