December 19th, 2011 09:25 AM #1
- Nov 2010
- Between Cups Of Coffee (AU)
- 2,424
- 46 Post(s)
- 216 Thread(s)
NVIDIA Plug-in For Photoshop (Texture Tools )
NVIDIA Texture Tools for Adobe Photoshop
This installer contains two plug-ins and several helpful scripts for Adobe® Photoshop®.
For Adobe Photoshop 5.0, 6.0, 7.0, CS, CS2, CS3, CS4 and CS5.
· NVIDIA Plug-in for Adobe Photoshop (32-bit) (8.51.0816.1945)
· NVIDIA Plug-in for Adobe Photoshop (64-bit) (8.51.0816.1945)
Release Notes
· DDS export now supports PSDs with transparent layers, but without alpha channel.
· DDS export now supports manually added alpha channels.
· DXT5 export now supports volume textures.
Attachment 50398
NVIDIA NORMAL MAP FILTER
The NVIDIA Normal Map filter creates normal maps from grayscale height maps. The filter UI provides a powerful 3D preview and a variety of filtering options. For MIP-mapped normal maps, the NormalMap Filter should be used for preview only, and then the grayscale map exported via the DDS plugin with "Normal Map Settings..." enabled. This will create a normal map with maximal detail and fidelity for all texture levels, without undesirable filter aliasing.
Attachment 50399
NVIDIA DDS PLUG-IN
The NVIDIA DDS plug-in supports the DXTC texture compression format and allows you to open and save .dds files in RGB format. It reads and writes .dds files in compressed or uncompressed forms, provides support for per-MIP color fading, MIP-corrected normal mapping, and more.
MIPSTER
Mipster is a mip-map generation script, for Photoshop CS2 and above, that leverages the power of Photoshop’s internal image filtering engine along with the (optional) NVIDIA DDS Plug-in and Normal Map Filter (for Windows). While Mipster will function without either of these NVIDIA plug-ins (e.g., on OSX), it works best in tandem with them. Running Mipster on any image will create a collection of mip-map layers in your current Photoshop document -- one layer per MIP.
CUBE MAP SHUFFLER
This script rearranges cube-map-face elements for use with different export and editing tools. It can quickly convert and copy between different cubemap layout formats, a task that has previously been annoyingly slow and error-prone. If you are used to editing cube map faces, you’ll find this script makes format changes a lot easier.
Attachment 50400
Attachment 50401
P.S Hope You Like EnjoyLast edited by 8pecxstudios; February 29th, 2012 at 09:51 AM.
Photoshop Tools Reference
By nofx1994 in forum CS4 Photograph TutorialsReplies: 4Last Post: September 17th, 2011, 08:23 PM -
.Ico plug-in for photoshop
By gor17981 in forum General QuestionsReplies: 7Last Post: December 20th, 2010, 10:36 AM -
Photoshop Tutorial - Episode 10 - Texture
By nofx1994 in forum Video TutorialsReplies: 1Last Post: December 1st, 2010, 08:54 PM -
You Suck at Photoshop: #7: Patch Tools and Levels
By nofx1994 in forum Video TutorialsReplies: 0Last Post: November 30th, 2010, 05:49 AM -
Wrap a texture or pattern around an object - Photoshop Week
By nofx1994 in forum Video TutorialsReplies: 0Last Post: November 16th, 2010, 12:56 AM
