Page 2 of 3 FirstFirst 123 LastLast
Results 9 to 16 of 17
Thread: Default Win 7 Task pane not restoring Share
  1. #9
    XXXxxxXXX is offline
    tripleX
    Nov 2010
    Germany, Rheinland-Pfalz
    17
    296
    2 Post(s)
    17 Thread(s)
    Maybe you could try this:
    boot from win7 dvd. Click the computer repair options. Choose the command prompt. Type in the following:
    sfc /scannow /offbootdir=X: /offwindir=X:\Windows
    You have to replace X with the drive letter from your windows partition. The letter is shown when it says "searching for windows installations" (before you can choose the command prompt). It does not have to be the same letter as you see it in windows!
  2. #10
    Mr GRiM is offline
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,511
    500 Thread(s)
    OK I am a bit lost here, what has changing the taskbar images got to do with the shell32.dll, any changes to a theme should only happen in a msstyles file located in C:\Windows\Resources\Themes have you tried installing another theme at all to see if it does change correctly?
  3. #11
    tripleX
    Nov 2010
    17
    296
    2 Post(s)
    17 Thread(s)
    It's not taskbar images, it's taskpane images. Correct me, if I'm false but I think this images are changed with shell32.dll?
    @Julio Or maybe you have installed a theme using theme resource changer? Then you have to rename the shell32.dll-folder in the theme folder.
  4. #12
    Mr GRiM is offline
    Bringer of Death
    36
    4,511
    500 Thread(s)
    OK sorry you mean the navigation pane on the left of the control panel and top?
  5. #13
    tripleX
    Nov 2010
    17
    296
    2 Post(s)
    17 Thread(s)
    I think so. Otherwise Julio hadn't written something about this program: [Only registered and activated users can see links. ]
  6. #14
    Mr GRiM is offline
    Bringer of Death
    36
    4,511
    500 Thread(s)
    well I have no idea why it didn't restore the original files but if your on a x64 OS did you check both files, the one in the system32 folder as well as the SysWOW64 folder? to check the files in the system32 folder you will need to copy it and paste it on your desktop, otherwise it will actually only look at the one in sysWOW64
  7. #15
    raogrimm is offline
    Mar 2011
    23
    77
    15 Thread(s)
    i'm no expert on this subject or anything, but have you tried to run the command prompt as admin? that's normally the case when it tells you that you don't have enough permission or if it just won't do it like in your situation. also do as grim said and check both syswow64 and system32 folders.
  8. #16
    8pecxstudios is offline
    Cyberfox Developer
    Nov 2010
    Between Cups Of Coffee (AU)
    2,608
    46 Post(s)
    204 Thread(s)
    Hi you could try this script in this .bat file run it as admin when it starts it will ask for admin priv's and it will also takeown of sfc.exe to enable more privileges hope it works out for you
  1. How to remove bar under detail pane ?
    By pats in forum General Questions
    Last Post: 04-12-2013, 06:07 PM
  2. Moving Pane to top
    By Mbrys331 in forum Explorer
    Last Post: 01-29-2011, 02:28 AM
  3. Windows 7 Task Pane Changer
    Last Post: 12-14-2010, 04:49 AM
  4. Move the navig. pane to right
    Last Post: 10-20-2010, 03:50 AM
  5. navigation pane
    By osman_2626 in forum Explorer and shell
    Last Post: 02-28-2010, 11:55 AM
