Page 2 of 2 FirstFirst 12
Results 9 to 16 of 16
Thread: 632 & 633 shell 32 replacement images Share
  1. #9
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    36
    4,527
    513 Thread(s)
    If your going to do it in the shell32.dll system file then you only need to change it for the system32 folder but as you found out, you need to copy it to your desktop and then add your new images and save it, then rename the original and and add your new one back in, but I do not recommend this method as it has more chance of going wrong plus using Theme Resource Changer means that you can have different images for each theme you select and it will all change with the theme without you needing to do anything.
  2. #10
    julio99 is offline
    Sep 2010
    Niagara Falls,On.,Canada
    58
    147
    14 Thread(s)
    I just changed the 633 and it worked real nice. I did it with the TRC and put it in the theme folder. Now the 633 I used was dark but the image underneath you could still see the diagonal stripes so I added a 200 x 600 PNG to the same shell 32 folder and renamed it 632. When I restarted there was a black image that covered about 2thirds of 633. What I wanted was for the 632 black to be underneath the 633, but obviously It doesn't work that way. How do I get a dark image underneath the 633 so you can't see the diagonal light stripes. I put the 632 in the same folder as the 633, but the PNG's weren't the same size as far as kb's. Somewhere the compression must be different to make 2 images 200 x 600 be a different size in kb's. I don't know I'm asking Mark.
  3. #11
    julio99 is offline
    Sep 2010
    58
    147
    14 Thread(s)
    Quote Originally Posted by The Archiver View Post
    my current 632 in png
    I did not know this would work with a black background> Very cool! I thought because it downloaded as a white background it would show as a white background. Does it ever look nice with the dark background. I'm starting to get the hang of these 632 and 633 images. Grim gave me a nice little tutorial on working with those and they really help a theme look good.
  4. #12
    arm is offline
    Mar 2012
    Germany
    13
    Thank you
  5. #13
    NinjaMonkeyz is offline
    Apr 2012
    Australia
    13
    1 Post(s)
    Hi,
    I was just wondering if anybody could give me a few words of advice.
    I can't seem to get the 635 Image to appear the one that says ALIENWARE in big red type.
    I put it where it was supposed to go and I have the entire theme working except for that.
    Im Pretty sure it's supposed to show up there.
    Any thoughts?
  6. #14
    zadar023 is offline
    VIP
    Feb 2010
    Croatia
    44
    451
    8 Post(s)
    153 Thread(s)
    you should have 635 png. and put in the folder the theme shell32.dll
    if you do not have one I give you this one 635 png. image and I think than you be will fine whit this...
    this is the from theme CoRE FACToR Red
    other one...
  7. #15
    Apr 2012
    Australia
    13
    1 Post(s)
    oh boy, Thanks for that mate. But I got it ... helps if you don't call it 0635 ... yyyyeah helps alot
  8. #16
    mp3tuan is offline
    Nov 2013
    VN
    4
    2 Thread(s)
    Someone could reup shell 32 with 632 633 plz? i need theme for editing
  1. Alienware Explorer.exe and Shell32.dll (633 & 635) replacement images
    By றѳѳղղįqվદ in forum Miscellaneous
    Last Post: 04-04-2013, 08:24 PM
  2. Replies: 7
    Last Post: 07-17-2012, 02:15 PM
  3. Shell replacement image
    By serschik in forum Theme & Extras Resources
    Last Post: 05-29-2012, 05:46 PM
  4. shell32 replacement image
    By cblackpanther in forum Shell32
    Last Post: 08-20-2010, 03:44 PM
  5. Shell32 Replacement Images
    By color in forum Shell32
    Last Post: 03-29-2010, 02:10 PM
