i don't know how many internal drives you have, but personally i would go for a mid tower not a full. mid's are cheaper not because less materials used to make them, but because they are ordered far more than full or mini towers are.
thanks i have a mid tower thermal-take V4 Black edition and for room and cable management it sucks and when trying to remover a HDD it's just hitting the PSU a little and overall not much room for when i can get a liquid cooling system and the other mid towers ive looked at arn't much better that's why i want to go to full tower plenty of room for upcoming improvements thanks heaps you guys have given much to think about and consider when upgrading tower's thanks heaps you guys rock
I guess I am an overspender..... I love a great big case no matter what the cost because I have quite a bit of hardware and like to leave plenty of room for things to add later such as a couple of radiators, reservoir and maybe even two pumps.
If I had a choice between all of those cases I would much rather have a HafX or better yet the new Coolermaster Cosmos II will be the next case that I purchase. The level 10 just doesn't excite me much since we have had it and thought it wasn't worth the money.
The coolermaster Storm Trooper is an amazing case as well. If you are looking to save money and still get a strong and sturdy amazing case with plenty of room to do whatever then I would suggest looking at the Rosewill Thor. Here are my top choices for full tower cases:
I have a Haf 932 Black Edition right now but once I am ready to buy the rest of my water cooling setup the Coolermaster Cosmos II is hands down the best full tower for the price. I have reviewed tons of cases and they are mostly all flimsy made side panels especially the Antec cases. All of the HAF series and most of coolermasters cases are exceptionally manufactured. Also the Rosewill cases are very rugged and nicely priced.
there is also mountainmods cases.![]()
i bought this one in 2005 and still very happy with it.
[Only registered and activated users can see links. ] [Only registered and activated users can see links. ] This item is IN STOCK!
The Ultimate in Computer Chassis - Mountain Mods award winning U2-UFO.
WORLDS ONLY HYPER MODULAR COMPUTER CASE
The new HYPER MODULAR design puts a new spin on an old staple! Options are seemingly endless.
NOW for water cooling enthusiasts choose your fan hole spacing for your specific radiators!(Thermochill or Swiftech/Black Ice)
In the front hold a Thermochill PA 120.3, Swiftech MCR320, or Black ICE Triple radiator while on the back choose Thermochill PA 120.2 or Swiftech MCR220/Black ICE Double radiator spacing.
The U2-UFO is the ultimate in computer case experience. Coming in at 18 inches cubed this box can hold just about anything and everything your heart could desire in a computer case. They can house up to 5 x 5.25 devices and up to a whopping 18 hard drives using Mountain Mods 120mm Fan Hard Drive brackets. Whether you are cooling with air, water, or phase changing solutions this is the case that can do it all. Not only does the U2-UFO have space to hold your high end components but with the high volume of air flowing in and out of the case it will keep them operating at cooler temperatures resulting in longer life and better performance. The U2-UFO is fabricated by skilled workers in the USA. It is made from thick aluminum making it lightweight, sturdy, and thermally friendly. Casters are included for easy mobility.
Discover space in a U2-UFO.
Assembly [Only registered and activated users can see links. ]
Specifications:
Material - Aluminum 5052
Thickness - 1.65mm-3.25mm
Dimensions - 18x18x18 inches
Finish - Powder Coat
Power Supplies - Holds up to 2
HD Bay - 2 sets of 120mm HD brackets - Holds 6 out of box, up to 18!!
5.25 Bay - Removable
5.25 Devices - Holds 5
MB Tray - Removable
Form Factors - mATX/ATX/EATX (EATX choose the optional MB Tray)
Fan Mounts - 7-120mm
Empty Weight - 15 lbs.
Also if you know what you are doing you can make your own case. Ive made a few out of plexiglass.
Mid Tower cases are great. What you need to do is pay attention to the sizes. Your V4 is only 7.5" wide. The width reduces the room on the backside of the MB plate. I have an HAF 922 and I love it. The width of the case is 10". That's 2.5" wider than your case. There is plenty of room for cable management and it is set up for water cooling.
Here is a link: [Only registered and activated users can see links. ]
$90 bucks after mail in rebate!!
