Page 11 of 36 FirstFirst ... 78910111213141521 ... LastLast
Results 81 to 88 of 285
    Mr GRiM is online now
    Bringer of Death
    Cairns, FNQ, Australia
    35
    4,163
    144 Thread(s)
    Star HUD LAUNCH Premium Windows 7 Theme
    PROUDLY PRESENTING FOR WINDOWS 7......
    The HUD LAUNCH theme is finally here and there are many new changes to the theme as well as a new icon set to match, this theme is not just a simple recolor, nearly everything has been changed and completely redesigned to produce an original creation that is a truly remarkable theme, the same goes for the icons, every icon has been recreated and tweaked so that the colours match the style perfectly and allot of the icons were designed again from scratch.
    The HUD LAUNCH theme extras can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
    Features:
    HUD LAUNCH Theme
    HUD LAUNCH Basic Theme
    HUD LAUNCH Topshell Theme
    HUD LAUNCH Topshell Basic Theme
    HUD LAUNCH Icons
    System Clock
    Shell32 Control panel images
    LAUNCH Cursors
    HUD Sound Scheme
    System Properties Logo
    Getting Started top Pane
    Games Menu Preview Pane
    And much more!!
    I would also like to add a big thanks to [Only registered and activated users can see links. ] for his permission to include his great wallpaper Injected Lapis [Only registered and activated users can see links. ][Only registered and activated users can see links. ]
    Mirror
    Additional Theme Extras
    AIMP 3 Skin By Gor
    WINRAR Skin By Gor
    Object Dock by Twizz
    MUI Side Images By Gor
    Desktop Gadgets by Pats
    Information
    Important! YOU MUST DO THIS FIRST!
    You must enable the use of custom themes by patching your system with Universal Theme Patcher
    Information
    Important Update!
    The installers for the Launch theme are now fixed and will now install Theme Resource Changer and the fonts, if you have problems with the start buttons and navigation buttons not showing then please download the theme again from the shop.
    Sorry for the inconvenience, this was my fault for not fully testing my installers after I altered some of the code
  2. #81
    Bringer of Death
    35
    4,163
    144 Thread(s)
    Here is another one I found that I recolored
  3. #82
    Bringer of Death
    35
    4,163
    144 Thread(s)
    Quote Originally Posted by SevenVirtues View Post
    I love this theme, my only complaint is that I cant read the text I'm typing on things like Word and Notepad.
    I find it hard to believe that you can not read the text in word and notepad, I can see the text just fine as in the example.
  4. #83
    SevenVirtues is offline
    Dec 2010
    18
    I can read it too, but when I'm using my laptop in a brightly lit area or writing a word doc it's not easy to read. Maybe you could make the background colour slightly darker - so the colours are the same as when you're writing a post on this forum
  5. #84
    Dec 2010
    18
    Quote Originally Posted by Krimian View Post
    I cannot get the start menu orb to appear. I can change to anything else but I cannot locate the one for this theme..... Any ideas?
    I had this too, if you install Theme Resource Changer manually it fixes it.
  6. #85
    fibonacci94 is offline
    Jul 2011
    Manila
    20
    46
    LOL
  7. #86
    Bringer of Death
    35
    4,163
    144 Thread(s)
    Try this, unzip it and put it in C:\Windows\Resources\Themes and then apply it in your personalize menu, it's going to mess up the theme a little bit but you can use it for when you need to do work in documents.
  8. #87
    twizzz is offline
    Dec 2009
    The Far Reaches
    35
    168
    1 Post(s)
    72 Thread(s)
    Quote Originally Posted by RCDawg85 View Post
    That Google Chrome icon is sweet. Does anyone know how to change the taskbar icon for that? I changed the Google Chrome icon itself, but when I open the program, it reverts back to the ugly red/yellow/green icon on the taskbar.
    I know you did it for Firefox...it is a theme-specific thing that I can't change?
    Dont know if your pinning it to the taskbar or not ... I do know that issue and the only way i know to do it is .. When you apply your icon change dont close Properties menu out leave it open... From there go to Chrome via the start menu.. Right click on the application and pin to taskbar should be listed.. It will pin it to your taskbar with the new icon... Close the Properties menu and your done..
  9. #88
    Ryan_Se7en is offline
    Oct 2009
    292
    35 Thread(s)
    I think it is doing fine. I'm testing it for a while and see no problem. Thanks Grim. I think you should include it in the next theme you do
    The Placebo Knitsch Object is also a dark theme but has white background for word, powerpoint, and excel. It has no problem, and the one you just make is good also.
  1. FREE!! HUD RED Premium Windows 7 Theme
    Last Post: 15 Hours Ago, 09:25 AM
  2. FREE!! HUD Premium Windows 7 Theme
    Last Post: 2 Weeks Ago, 09:08 PM
  3. FREE!! Toxic Premium Theme Pack
    Last Post: 03-05-2013, 04:46 AM
  4. FREE!! H2O Premium Theme Pack
    Last Post: 02-14-2013, 04:05 AM
  5. Airlock Premium Theme
    By gor17981 in forum Windows 7 Premium Themes
    Last Post: 02-03-2013, 09:34 AM
