The HUD LAUNCH theme is finally here and there are many new changes to the theme as well as a new icon set to match, this theme is not just a simple recolor, nearly everything has been changed and completely redesigned to produce an original creation that is a truly remarkable theme, the same goes for the icons, every icon has been recreated and tweaked so that the colours match the style perfectly and allot of the icons were designed again from scratch.
The HUD LAUNCH theme extras can be installed or uninstalled using 7tsp found [Only registered and activated users can see links. ]
Features:
HUD LAUNCH Theme
HUD LAUNCH Basic Theme
HUD LAUNCH Topshell Theme
HUD LAUNCH Topshell Basic Theme
HUD LAUNCH Icons
System Clock
Shell32 Control panel images
LAUNCH Cursors
HUD Sound Scheme
System Properties Logo
Getting Started top Pane
Games Menu Preview Pane
And much more!!
I would also like to add a big thanks to [Only registered and activated users can see links. ] for his permission to include his great wallpaper Injected Lapis [Only registered and activated users can see links. ][Only registered and activated users can see links. ]
Mirror
Additional Theme Extras
AIMP 3 Skin By Gor
WINRAR Skin By Gor
Object Dock by Twizz
IE Nav buttons By Smober
MUI Side Images By Gor
Desktop Gadgets by Pats
Information
Important Update!
The installers for the Launch theme are now fixed and will now install Theme Resource Changer and the fonts, if you have problems with the start buttons and navigation buttons not showing then please download the theme again from the shop.
Sorry for the inconvenience, this was my fault for not fully testing my installers after I altered some of the code![]()
HUD LAUNCH Theme
s , grim saved the day as usual , what would we do without him , matter of fact i dont wanna imagine how horrible my os would look like without his skillz
