Page 3 of 5 FirstFirst 12345 LastLast
Results 17 to 24 of 36
    razorsedge is offline
    Cyberfox Co Developer
    Oct 2009
    38
    4,785
    16 Post(s)
    97 Thread(s)
    How to patch windows 7 to allow 3rd party themes and apply themes video tutorial
    How to patch your windows 7 system to use 3rd party themes
    and apply themes that don't have installers
    Universal Theme patcher
    Universal theme patcher is a silent install for both x86 and x64 just double click and it will patch the theme files for you. There will be no windows that show or anything you have to click it patches it all for you.
    Theme resource changer
  2. #17
    dareaper is offline
    Jan 2010
    34
    91
    Excellent tut,thanks.
  3. #18
    spenny57 is offline
    Dec 2012
    bourgogne
    19
    1 Thread(s)
    merci beaucoup
    Translation = thank you very much
    Please Post In English Or Provided Translation
    Thanks
    VC Staff
  4. #19
    Cruel is offline
    Jan 2013
    EU
    31
    22
    3 Thread(s)
    Great tutorial Thx!
  5. #20
    Life is offline
    Feb 2013
    USA
    5
    2 Thread(s)
    Help!!!! I downloaded this theme, and cannot figure out how to set it up. I was only able to change the desktop background, and nothing else. I downloaded the patcher, and restarted my computer, but cannot figure out how do change the entire interface of windows 7, like shown in the video^^ Please help.
  6. #21
    ONE MAN ARMY is online now
    Moderator
    Apr 2011
    San Diego California
    29
    599
    68 Thread(s)
    Quote Originally Posted by Life View Post
    You will need to patch your compter like shown in the video. Once that is done you also need to download and install Theme Resource Changer. Below the video is a link to tutorial for that!
  7. #22
    Life is offline
    Feb 2013
    USA
    5
    2 Thread(s)
    Thanks, but even after I downloaded that, it said that I could not install because I had the wrong version of windows. But I downloaded the one for win 7 32 bit(which is what I have). I was able to change the desktop icons, and my courser, but that is it. And now that I have moved and who knows what else, I'll have to re download the file in order to get it working. Anyways, I could not get it to work
  8. #23
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,786
    21 Post(s)
    259 Thread(s)
    ok first thing you need to do is patch your sytem using universal theme patcher this will allow the use of third party themes it can be found here [Only registered and activated users can see links. ] this is a silent install and will do all the work of patching your system for you and will enable your system to wear third party themes
    Next you need to install theme resource changer on to your system [Only registered and activated users can see links. ] this app allows the images in the theme to load into memory instead of having to manually edit all those images
    Next make sure you are placing the correct theme files into to the proper file location c/windows/resources/themes
    each theme should consist of two things
    1. a .theme file
    2. the theme folder containing the msstyle file and the different image files
    Both of these need to be copied to the above location then you can right click your desktop and select the personalize menu and you should now see your newly installed theme available for selection
    Keep in mind themes and icons are totally a separate thing. Icons have to be applied separately from themes
  9. #24
    peter.pan is offline
    Moderator
    Jul 2011
    276
    1 Post(s)
    34 Thread(s)
    Hi Life also....after you did everything that Big V mentioned ...if by chance you have some images that dont load like back and forth buttons or top image in control panel or
    side panel in updates then open a window go up top to tools,scroll down to folder opsions click on that then click view in the box list below UNCHECK the box : launch folder
    Windows in separate process ..... press apply and ok ....Thats it ...
  1. How to apply a 7tsp pack video tutorial
    By razorsedge in forum Theme & Extras Setup Tutorials
    Last Post: 03-29-2013, 03:46 AM
  2. Edit Dll images apply icons theme extras video tutorial
    Last Post: 01-25-2013, 08:58 PM
  3. Need Help With windows 7 themes
    By PARADOXMAX in forum Requests
    Last Post: 02-10-2012, 10:22 AM
  4. Changing 7tsp patched themes: patch for every change?
    By Saintzer0 in forum General Questions
    Last Post: 02-06-2012, 11:57 PM
