I'll have to give it a try in a bit. Thanks for the post.
hi guy's here is a video to give info on what the results mean ok
basically the lower Scores
FPS:
Score:
And
Max FPS:
At The Highest Settings The Better The Card Is In Performance So That Means The Better The Games Will Be When Played At There Highest Settings
looks OK bud, I did a comparison with the same settings you used and my CPU clock is at 4.1Ghz at the moment, had a system reboot while playing BF3 yesterday at 4.4Ghz so decided to just drop it down a bit instead of increasing the stock voltage.
GTX580 Overclocked to 900Mhz
Here's what I was able to churn out with those settings
Very nice, is that Crossfire your running there?
yup cards are in crossfire, the visiontek used to have the extra shaders unlocked but due to the diamond card not able to unlock they are both on original bios with a mild OC 840/1325 on stock volts......I was hoping the diamond card being a ref card it would unlock but I've tried just about every way mentioned and no luck
