Results 1 to 4 of 4
Thread: VSB Template Photoshop Preset (Settings) Share
    FalloutDezignz is offline
    Mar 2012
    Massillon, Ohio
    24
    5
    Post VSB Template Photoshop Preset (Settings)
    Best Vista Style Builder PSD Template Preset Settings?
    Little confused, I much appreciate any input, suggestions, or tips you may be able to give.
    Lets say im going to start with a desktop theme template, and save it as PSD, or TIF for quick and easy editing later.
    I seen many people had problems with there images being stretched on the start menu
    resulting in pixel(y) corners, or mis-alignment...etc
    Definitely want to prevent this from the beginning so later I don't have to hassle with it.
    Current Photoshop(CS-5/6) settings for my template are:
    1) Currently running on a laptop (Widescreen) so also wondering if i should leave the "Pixel Aspect Ratio" alone?
    Current Screen Resolution on laptop - 1280x800
    2) Does is really matter?
    also wondering if my current screen resolution should have an effect on how big the size of my template should be, i was thinking start with a template in PS at 1280x800, instead of 1024x1024 (This way i know if it looks good on my screen then it should be ok on others as well who may have wide-screen)
    Resolution: 72 (Pixels/Inch)
    Color Mode: RGB Color 16bit
    Background Contents: Transparent
    Color Profile: Working RGB: sRGB IEC61966-2.1
    Pixel Aspect Ratio: Square Pixels
    When finished & Saving:
    No Compression I will also assume would have better quality (Correct me if I'm wrong)
    Interlaced - I use None ( Have no idea what Interlaced is)
    When finished, the individual pieces are saved as PNG. BUT which way?
    used to website design... so with a desktop theme which method is proper or better
    file/Save As/ PNG
    or
    File/ Save for Web and Devices / PNG-8 or PNG-24
    (blah all these new PS5/6 settings nowdays... i remember back when.... photoshop 7 ..... xp... blah blah... nuggets. (2hrs later)
    blah blah blah and a pack of cigarettes was a nickel...
    After this is solved I will post the PSD for others who may need it to save time with sizing/settings leaving only the design portion left for there projects.
    Thank you
    Harvey Sewdin is online now
    The Mentalist
    May 2011
    Latour, Paramaribo, Suriname
    19
    1,773
    27 Post(s)
    521 Thread(s)
    Bud, when making a theme you must try to make some part as small as possible. Because someone else may not have such a big screen or use such big images. example, if you have 10 items in your startmenu then maybe your startmenu height will be 500px(example) and maybe someone else is using 5 items then his startmenu height will be 250px. if your startmenu image is 100px(the height i mean), and it is stretched/tiled right then no one should have a problem. the image would automaticaly stretch/tile to 250px or 500px. BUT if the startmenu image was 500px then the person with 5 items would get a cutted image, because the image would then have to resize from his original size(500px) to a smaller size (250px). So try to make the images small.
    If you have a high detailed image and you want that it should come completely maybe 200px width and the default size of that part is 100 px, then you can change the margin using CONTENT MARGINS. this puts a margin between your content (maybe text) and you bg-image.
    About saving your images, i use standard PNG, not-interlaced. I haven't used PNG for web and devices because i think it slightly changes to colors to make it 'websave' (i am not so sure about it bud). Websave has to do colors, a whole different story.
    If you want to know more, just ask then bud.
    Mar 2012
    Massillon, Ohio
    24
    5
    Quote Originally Posted by Harvey Sewdin View Post
    Thanks Brother. I plan to mess with Tiled and prevent that from happening. I thought about it at first. seen other templates using tile instead of stretch for certain start menu sections so now i know 4sure that's probably the best method to use.
    ill post further updates as they come.
    The Mentalist
    May 2011
    19
    1,773
    27 Post(s)
    521 Thread(s)
    good luck then.
  1. Which Preset?
    By HitMeDoN in forum OS & Hardware Help and Support
    Last Post: 10-01-2012, 03:34 AM
  2. New template for www-designfjotten-com finished!
    By designfjotten in forum Web Builders Den
    Last Post: 07-18-2012, 02:58 AM
  3. You Suck at Photoshop: #16: Define Brush Preset
    By nofx1994 in forum Video Tutorials
    Last Post: 12-01-2010, 08:45 PM
  4. how to reset your photoshop to default settings
    By _Deano_ in forum General Tutorials
    Last Post: 08-25-2010, 08:36 AM
