not sure I understand your question bud
Okay I know this is probably a lazy post... but I was just wondering if it is possible to change the LED color sequence. For example I would like to use a Red colored theme in my OS so I could avoid pressing the LED on the case![]()
Hi Bud There should Be A Button On Top of The Case Called Fan Led use that to cycle to the color you want it's near the fan speed button here is a video about the case hope it helps
for example when you open up Thermaltake Level 10 GT the default color of the LED is Blue... then you have to press the LED button to go to the color you want, what i'd like to ask is if it's possible to change the default color when you start it up... for example use the RED Led color when you turn on your PC![]()
