Results 1 to 6 of 6
Thread: Create a simple realistic shadow effect
    Harvey Sewdin is offline
    The Mentalist
    May 2011
    Latour, Paramaribo, Suriname
    2,081
    27 Post(s)
    713 Thread(s)
    Ktip Create a simple realistic shadow effect
    This is how I create a ‘reallife positioned’ shadow for objects. Usually you have to use the brush tool, but this trick is easier. Follow these 5 steps.
    STEP 1
    Prepare yourself. Place the object you want to give a shadow to in your document. I used this scrap monitor.
    STEP2
    Go to blending options(right click on the object layer and select blending options in the list), and apply a standard drop shadow effect.
    STEP 3
    Now we have to separate the object and the drop shadow effect of each other. To do that right click on the “fx” logo on your object layer and select create layer
    This is how it should look like when done
    STEP 4
    Select the created shadow layer, right click on it and select free transform path. Resize the height a bit to half of the object.
    Right click on the transformation and select perspective. And resize it as shown in the image below.
    STEP 5
    Almost done! Select the shadow layer and go to Filter>Blur>Gaussian blur. Change the radius pixels to how much you want. I used 6.5.
    DONE! Here you have a nice dropshadow! I hope this tut has helped you.
    "BEST IN THE WORLD"
    VIRTUAL CUSTOMS TEAM MEMBER
    PLEASE REP THE ARTIST IF YOU LIKE A POST OR DOWNLOAD IT
    HARVEY'S DESIGNS
  1. How to give shadow effect to placelist text in start menu?
    By kumaramy in forum Miscellaneous questions
    Last Post: June 13th, 2013, 03:58 PM
  2. Realistic Fire Text Effect - Photoshop CS5 Tutorial
    By _Deano_ in forum PS CS5 Tutorials
    Last Post: July 16th, 2012, 11:21 AM
  3. Create a simple gadget (without javascripts)
    By Harvey Sewdin in forum General Discussion
    Last Post: July 16th, 2011, 02:26 PM
  4. Create the Matrix Effect - Photoshop Tutorial
    Last Post: May 16th, 2011, 09:42 PM
  5. Replies: 0
    Last Post: July 29th, 2010, 05:42 AM
