I cant get my skin to apply. I saved it as the right file type/format. And it doesnt wanna load in it for some reason. Im just trying to start somewhere on this website.
Ill include the file that i saved it as Maybe someone can help me with it.Man i suck at this editing and stuff for windows. I should stick with pictures and wallpapers.
Well thanks in advance if anyone helps me if not thanks anyways for looking
Do you have the latest versions of aimp3 and the skinner, If you have not try updating those. I have some issues in the past using newer versions of the skinner on older versions of aimp, vice versa.
good timing on this thread. i actually was once and for all going to do a thread about aimp3 skins. using a aimp3 skin depends on the skin itself. some you can only get to work by going through the aimp3 to install it, others will only work if you navigate to the aimp3 skins folder and drop the skin in it, others it doesn't matter which way you do it. this behavior is regardless of which aimp3 version you have.
I have the latest skinner and aimp3. I downloaded both before i even did anything. This was my first time downloading this program. but yes i have the lastes is says aimp3
