Page 5 of 7 FirstFirst 1234567 LastLast
Results 33 to 40 of 49
    razorsedge is offline
    Cyberfox Co Developer
    Oct 2009
    38
    4,784
    16 Post(s)
    97 Thread(s)
    One Vision the Retribution 7tsp pack
    Hi all
    Well after nearly a mth of work I have finally finished the icon packs for Retribution this is the 7tsp pack it does not include winrar themes or apps icons those can be found in the full pack in my themes section
    The full pack including apps icons, dock icons and winrar themes can be found here [Only registered and activated users can see links. ]
  2. #33
    IZOD is offline
    Dec 2011
    ZP
    30
    431
    206 Thread(s)
    wow wow wow it's just a beautiful set of icons look amazing really great job, thank you Razorsedge
  3. #34
    glassyeyed is offline
    Sep 2010
    133
    30 Thread(s)
    Quote Originally Posted by razorsedge View Post
    sry that would be the only way is to remove the pack and and remove the file from it then reinstall it's an optional problem as in some ppl get it and some don't there is no explination as to why it happens for some machines and not others
    If you have already installed the icon pack and have not seen razoredges solution above I've just come up with a very simple way to restore the network icon in the notification area for those of us who are unable to enable it in the notification area without uninstalling and re-installing the One Vision the Retribution 7tsp pack.
    Note: Only the network icon will be restored to the original default one leaving the rest untouched.
    Heres how:
    1) Start you computer in Safe mode by pressing F8 during just after Bios post.
    2) Start the 7tsp program and select - Program > SFC/Scan > SFC/Scanfile
    from the menu at top and browse to C:\Windows\System32\pnidui.dll.
    3) After the scan is complete restart your computer and you should now see the Network icon in the notification area.
    Also note that if you are running a 64 bit system there is another "pnidui.dll" file located in C:\Windows\SysWOW64 folder but is irrelevent.
  4. #35
    றѳѳղղįqվદ® is offline
    VC Mod.Monica Ygrasilova
    Norway (Oslo)
    17
    806
    23 Thread(s)
    looks of this 7tsp pack killed me
    really amaaaazing work
    [Only registered and activated users can see links. ] as always
    now i must test it,because i it
    again,really nice/hard work
  5. #36
    HammerJack is offline
    Aug 2011
    315
    1 Post(s)
    218 Thread(s)
    Thanks for the hard work put into these, and the desire to share your artistic skills with all the members..
    You rocka!!
  6. #37
    ChuckysChild is offline
    Elite
    Nov 2010
    49
    1,105
    170 Thread(s)
    Quote Originally Posted by glassyeyed View Post
    Heres how:
    another option to get to safemode for those of you who have your run command on your startmenu or know how to get to run box you can type msconfig and goto the boot tab. once there select safe boot, apply and restart. now before doing the steps
    [Only registered and activated users can see links. ] has laid out once in safemode goto run, msconfig, boot tab again and uncheck safe boot, apply, exit without rebooting. now preform the steps outlined by [Only registered and activated users can see links. ], and restart your system when done.
  7. #38
    Ryan_Se7en is offline
    Oct 2009
    292
    35 Thread(s)
    Am I missing the wmp icon or the pack simply doesnt have it?
  8. #39
    Oct 2009
    38
    4,784
    16 Post(s)
    97 Thread(s)
    Quote Originally Posted by Ryan_Se7en View Post
    I commented previously on this the manual pack in my themes section contains the wmp icon the 7tsp pack does not as I am using windows 7 N because it does not contain wmp, mediacenter or ie windows applications i dont want or use
    so I do not have the wmploc.dll to mod or make the required res file to put in the pack
  9. #40
    Elite
    Nov 2010
    49
    1,105
    170 Thread(s)
    warning folks if you have your details pane, and or command bar/folder band moved this icon pack will restore them to their default locations. it is easy to find a tut on moving the details pane, but finding one for moving the command bar/folder band is not.
  1. 7tsp Aurora icon pack
    By றѳѳղղįqվદ® in forum 7tsp Icon Packs
    Last Post: 2 Days Ago, 05:35 AM
  2. 7tsp Blade Icon Pack
    By Mr GRiM in forum 7tsp Icon Packs
    Last Post: 1 Week Ago, 09:32 PM
  3. Blue Black Elegant Icon Pack no topshell x86 x64 7tsp pack
    Last Post: 3 Weeks Ago, 04:43 PM
  4. 7tsp Fire Icon pack
    Last Post: 12-03-2012, 09:36 PM
  5. 7TSP HUD ICONS PACK
    By DEEPLOVE1 in forum Icons
    Last Post: 10-31-2011, 06:46 PM
