Page 1 of 2 12 LastLast
Results 1 to 6 of 7
Thread: expstart.exe error on startup Share
    Advy is offline
    Mar 2012
    Finland
    10
    37 Thread(s)
    So I applied an icon pack with 7tsp and now I'm getting an error with expstart.exe each time windows boots up.
    The error states the following: (giving me 3 errors)
    expstart.exe
    Failed to update BITMAP '6801':24
    Failed to update BITMAP '6805':24
    Failed to update BITMAP '6809':24
    So I've got no clue how to get rid of these errors, any help is much appreciated.
    Thanks beforehand!
    Big V is offline
    A Supreme God
    Feb 2010
    Cornfeilds of Indiana
    2,698
    21 Post(s)
    297 Thread(s)
    Those are the bitmaps for your start orb
    What pack did you install bud?
    I would run 7tsp again and use the system file restore to before 7tsp was ran
    Also did you install over top of an already existing 7tsp pack with out doing a restore first this will cause problem also
    Please Post In English Only
    Don't forget to leave Comments and Rep to the artist if you like or use their artwork.
    Thanks VC Staff
    Advy is offline
    Mar 2012
    Finland
    10
    37 Thread(s)
    Quote Originally Posted by Big V View Post
    I installed the Prometheus icon pack from razorsedge just as instructed. I removed the previous pack with 7tsp (was using Mark's Zero-G before). I updated my start orbs manually before running 7tsp cus the icon pack didn't include start orbs (so I left it unchecked in 7tsp). Otherwise my system runs perfectly. I just receive those annoying errors on startup. So the easiest workaround is to redo the installing process with the Prometheus icon pack?
    Big V is offline
    A Supreme God
    Feb 2010
    2,698
    21 Post(s)
    297 Thread(s)
    How did you update the start orbs? Did you use an app to change them? A lot of those start orb apps cause conflicts
    Thanks VC Staff
    றѳѳղղįqվદ® is offline
    VC Mod Monica Ygrasilova
    Norway (Oslo)
    22
    1,507
    Quote Originally Posted by Advy View Post
    hello Advy
    anytime you can change your start orb with using application
    Theme Resource Changer
    just copy any start orb png or bmp file to your original theme directory
    c/windows/resources/themes/your theme directory/explorer.exe
    if are not created,add here new folder and rename it to explorer.exe
    then copy and paste any start orb image and rename it to number 6801 6805 and 6809
    what is Theme Resource Changer
    you can download it and read other instructions how to use here
    http://virtualcustoms.net/showthread.php/30902-Theme-Resource-Changer-no-more-dll-editing
    or you can watch my youtube video here
    video time 2:44
    bachbeet is offline
    Dec 2011
    San Diego
    193
    300 Thread(s)
    Advy: Moonique's right. Use Theme resource changer for the start orbs. Much easier. In fact, it's much easier for the ex frame and shell32 images too. Use Greenfish to change bmps to pngs (it's a very useful free program for a lot of other things too). And, just change the icons when using 7tsp packs. I've run into trouble when having the 7tsp also change the logon screens. In fact, some creators recommend deleting the authui files to prevent problems. I think the authui files have something to do with the logons so I usually get rid of them in the 7tsp pack.
  1. HOW TO RUN FULL GLASS @ STARTUP
    By zyrandiel in forum Software
    Last Post: 03-03-2012, 01:28 PM
  2. Startup sound
    By Kyron in forum Theme Issues
    Last Post: 09-28-2011, 09:31 PM
  3. Troubleshoot Volume Activation error codes and error message
    Last Post: 03-01-2011, 06:29 AM
  4. Startup MessageBox Maker
    Last Post: 08-31-2010, 08:52 PM
  5. Startup Orb
    By Psych0t1c in forum Start Orbs
    Last Post: 11-23-2009, 10:56 AM
