Thread: Multi Commander silent installer
July 21st, 2012 09:47 AM #1
Author: Mathias Svensson
https://multicommander.com/
License: Freeware
Requires: Win 7
Multi Commander is a multi-tabbed file manager that is an alternative to the standard Windows Explorer. It uses the very popular and efficient dual-panel layout. Multi Commander has a everything you need in your daily works with files to make your work fast and efficient.
It has all the standard features like a file manager has like copy, move, rename, view. But Multi Commanders big strength is the special features that allow you to do advanced task with ease. Like Auto- unpacking, Auto-sorting, Browse inside archives, Workspace support, Scripting, Searching and a lot more. And it allows you to do everything from the keyboard.
Features:
Tabs allowing you to have multiple folders open.
Caching that enable fast file browsing.
Background work for all tasks that takes time to finish, allowing you to continue working without interruptions.
Customize the layout and colors to fit your styling needs.
Extensions and plugins that will increase the functionality of Multi Commander.
FTP, Registry , Zip, 7-Zip, Rar , Tar , GZ , Bz2 , Jar Support
View and Change file permissions, Take ownership of files.
Picture tools like Convert / Rotate Pictures, View/Remove EXIF tags, Adjust EXIF Date of pictures.
Show Movie information from IMDB/Rotten tomato as extra columns on you movie files.
Audio tools like View Audio file properties, View/Edit MP3 Tags.
Open API for developers to create extensions and plugins.
Remember selections when you get back from another location when browsing the filesystem.
Use mouse and drag and drop or use quick keyboard command for all the task.
FileOperations plugins that can automatically sort / unpack files when they are moved or copied.
File viewer that lets you view files of any size, as ASCII/Unicode/UTF8/Binary and Hex.
Both 32bit and 64bit versions available.
Handle folders with many thousands of files with easy, And use power full filters to limit what you want to view.
Compare folders and select the files and folders that are different, that are the same and many other options.
Power full script engine allowing you to create script that automate tasks.
Portable. Can be installed and run from portable (USB) device. Will not write any settings/session info on host computer
https://www.ryanvm.net/forum/viewtopic.php?t=9718
GPU-Z silent installer
Cypherix LE silent installer
By razorsedge in forum SecurityReplies: 1Last Post: August 16th, 2011, 01:38 AM -
CPU-Z silent installer
Router Commander Free Edition silent installer
By razorsedge in forum Internet\NetworkReplies: 1Last Post: May 15th, 2011, 01:48 AM
