July 22nd, 2012 05:24 AM #1
Autorun Eater 2.5 silent installer
Author: Old McDonald
https://oldmcdonald.wordpress.com/
Requires: Win XP/2003/Vista/Windows7
Autorun Eater was born due to the increase of malwares using the ‘autorun.inf’ method to infect users unknowingly be it from flash drives, removable hard disks or any other removable storage device. When a device is infected with a malware and an ‘autorun.inf’ file is dropped, the shell menu is normally modified to execute the malware whenever the unsuspecting user accesses the infected drive.
Autorun Eater will warn you and remove any suspicious ‘autorun.inf’ files(based on user decision/settings) so that the malware is not executed while accessing the infected drive. There are also certain cases whereby the malware has been removed by an antivirus but the ‘autorun.inf’ file remains. This will cause the drive to be inaccessible through the conventional method(double-click). Autorun Eater will also remove it if necessary so that you can access the drive as usual.
Features:
+ Prevent malware infection through removable storage devices(pendrives, portable hard disk, etc)
+ Install and forget, Autorun Eater monitors all drives(except A:, B:, and CD/DVD drives) in real time!
+ Manually scan drives A: and B: if you have access to either one or both(eg. Floppy)
+ Pause at any time
+ Deleted suspicious ‘autorun.inf’ file(s) are auto-backup’ed
+ Events are logged for future reference
+ Fix 3 common critical registry changes made by malwares
Autorun Manager
By razorsedge in forum Tweaking and TuningReplies: 0Last Post: January 21st, 2011, 11:14 PM -
NoAutorun: AutoRun Disabler by ~MasroorAijaz
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: November 1st, 2010, 11:58 PM -
Disable Autorun Functionality in Windows Using Registry Edit
By razorsedge in forum Setup TutorialsReplies: 0Last Post: July 29th, 2010, 12:37 AM -
Making an Autorun menu for wpi on your custom os
By razorsedge in forum Instalation TutorialsReplies: 0Last Post: July 28th, 2010, 11:42 PM
StartAllBack v3.7.7 for Windows 11 21h2-23h2++ Theme and Font Color fix by Moonnique StartAllBack Transparency
StartAllBack Theme and...
