July 22nd, 2012 05:31 AM #1
Bulk Rename Utility 2.7.1.2 silent installer
uthor: Bulk Rename Utility https://www.bulkrenameutility.co.uk/Main_Intro.php
Requires: Win 2000/03/08/XP/Vista/7
Bulk Rename Utility is a free file renaming software for Windows. Bulk Rename Utility allows you to easily rename files and entire folders based upon extremely flexible criteria.
Add date/time stamps, replace numbers, insert text, convert case, add auto-numbers, process folders and sub-folders....plus a whole lot more!
Rename multiple files quickly, according to many flexible criteria.
Rename files in many ways: add, replace, insert text into file names. Convert case, add numbers. Remove or change file extensions.
Check the detailed preview before renaming.
Rename photos using EXIF meta data (i.e. "Date Picture Taken", "Resolution" and other information embedded in all JPG photo files) Rename your holiday pictures from a meaningless dsc1790.jpg to NewYork1.jpg in a flash.
Rename MP3 files using ID3 tags (a.k.a. MP3 ID3 tag renaming).
Change files' creation and modification time stamps.
It's free. Easy to Install. Download and start renaming your files now!
Rename aero.msstyles
By tistou77 in forum General Windows 11 CustomizationReplies: 7Last Post: February 27th, 2023, 01:12 PM -
How to Import (Restore) All Tasks in Bulk Using Task Schedul
By razorsedge in forum Setup TutorialsReplies: 1Last Post: May 23rd, 2018, 06:26 AM -
how to rename a theme??
By twisla in forum Theme IssuesReplies: 2Last Post: October 29th, 2012, 09:25 PM -
Rename Master silent installer
By razorsedge in forum Unlockers and renamersReplies: 0Last Post: July 21st, 2012, 10:34 AM
the blocking of the StartAllBack application is moved to a new level from now on, some of the web browsers block the official page of the StartAllBack application it is therefore necessary to turn...
StartAllBack for Windows...
