https://support.microsoft.com/kb/314834
Some third-party programs can temporarily store unencrypted (plain-text) passwords or other sensitive information in memory. Because of the Windows virtual memory architecture, this information can be present in the paging file.
Although clearing the paging file is not a suitable substitute for physical security of a computer, you might want to do this to increase the security of data on a computer while Windows is not running.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 How to back up and restore the registry in Windows
To have us clear the windows paging file at shutdown for you, go to the "Fix it for me" section. If you prefer to fix this problem yourself, go to the "Let me fix it myself" section.
https://www.mediafire.com/?ig277lgafer7kil
