July 22nd, 2012 05:52 AM #1
Drive Speedometer 1.0.0 silent installer
Author: PcWinTech https://www.pcwintech.com/
License: Freeware
Requires: Win7/Vista/XP
Drive Speedometer is a program I made to help monitor the current read and writes speeds of your hard drives.
Benefits include:
1. When your system is running slow yet your CPU usage and memory usage are fine, it is normally the hard drive being maxed out. Now you will be able to keep an eye on the hard drive performance.
2. When a drive is slowly dying it will run slower and slower. Being aware of what your normal drive speeds are and seeing those speed drop over time is a great indicator it is time to replace the drive.
3. Being a performance nut myself I like knowing what my system is doing. When I have a program doing some work and appears to be hung up I can see if it is still reading or writing to the drive. This way I know the program isn't hung up and is still working.
The program uses the Windows performance counters to pull the information. If you have disabled your performance counters I have included a reg file in the setup to enable them again. Run the reg file and reboot. Your performance counters will be working again.
I have also included some pre made bar fill graphics. Including some to use when running the monitor in compact mode. You can of course make your own as well.
GPU-Z silent installer
DVDFab Virtual Drive silent installer
By razorsedge in forum CD/DVDReplies: 0Last Post: July 21st, 2012, 07:16 AM -
SPEEDOMETER WALLS
By RIMARU in forum Wallpapers Posted by RIMARUReplies: 2Last Post: February 21st, 2011, 11:41 PM -
SPEEDOMETER MULTICOLOR
By RIMARU in forum Wallpapers Posted by RIMARUReplies: 5Last Post: October 28th, 2010, 04:22 PM
Post Your Windows 11...
