July 22nd, 2012 06:19 AM #1
HashCheck Shell Extension 2.1.11 silent installer
HashCheck Shell Extension description
An extension that makes it easy for you to calculate and verify file hashes/checksums from Windows Explorer.
HashCheck Shell Extension will help you calculate checksums from you contextual menu.
First, HashCheck can process and verify the hashes/checksums stored in checksum files--these are files with a .sfv, .md4, .md5, or .sha1 file extension. Just double-click on the checksum file, and HashCheck will check the actual checksums of the listed files against those specified in the checksum file.
Finally, if you want to create a checksum file but think that opening the file properties dialog, navigating to the "File Hashes" tab and then clicking "Save" is too much trouble, HashCheck simplifies the task by adding an optional "Create Checksum File" command to Explorer's context menu. Simply select the files and directories that you want to hash and create a checksum file for, right-click on them, and select "Create Checksum File".
CPU-Z silent installer
Classic Shell 2.9.3 silent installer
By razorsedge in forum MiscellaneousReplies: 1Last Post: March 6th, 2011, 06:09 AM -
Windows Registry shell extension
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: January 26th, 2011, 05:25 AM -
Font Properties Shell Extension For Windows 7
By razorsedge in forum MenusReplies: 0Last Post: August 4th, 2010, 06:16 AM
