July 22nd, 2012 08:07 AM #1
Universal ASIO Driver For WDM Audio 2.10 silent installer
https://www.asio4all.com/
ASIO4ALL is a hardware independent low latency ASIO driver for WDM audio devices. It uses WDM Kernel-Streaming and sometimes even more sophisticated methods to achieve its objectives.
In order to successfully run ASIO4ALL, you need:
- A WDM-compatible operating system, such as Win98SE/ME/2k/XP/2003/XP64 or Windows Vista x86/x64.
- A WDM-driver for your audio hardware. (Under Win2k/XP/Vista... this is implicit, not so under Win98SE/WinME.)
- A couple minutes of your time and a little bit of luck.
ASIO4ALL will NOT do:
- Replace your existing sound card drivers or mess with them in any way.
- Install any kernel mode components that could potentially affect the stability of your system.
- "Overclock", or otherwise operate your audio hardware in ways that could potentially be harmful and/or void your warranty, except, of course, in cases where the manufacturer of your hardware has specifically stated that the use of ASIO4ALL would void your warranty indeed.
Universal Theme Patcher 1.5 silent installer x86 & x64
By razorsedge in forum Theme PatchersReplies: 18Last Post: April 13th, 2020, 07:43 PM -
Universal Media Server silent installer
By razorsedge in forum Internet File Management AppsReplies: 0Last Post: July 30th, 2012, 07:22 AM -
Universal Viewer 5.5.4.2 silent installer
By razorsedge in forum UtilitiesReplies: 0Last Post: July 22nd, 2012, 08:10 AM -
MediaHuman Audio Converter silent installer
By razorsedge in forum Audio AppsReplies: 0Last Post: July 21st, 2012, 09:55 AM -
Universal ASIO Driver For WDM Audio 2.10 (ASIO4ALL) Silent
By razorsedge in forum Hardware/DriversReplies: 0Last Post: October 14th, 2010, 10:04 PM
foobar2000 v2.1.5 Dark...
