Thread: RealTemp Normal Insaller
October 8th, 2012 03:29 AM #1
- Nov 2010
- Between Cups Of Coffee (AU)
- 2,424
- 46 Post(s)
- 216 Thread(s)
RealTemp Normal Installer
Real Temp
Real Temp is a temperature monitoring program designed for all Intel single Core, Dual Core, Quad Core and Core i7 processors. Each core on these processors has a digital thermal sensor (DTS) that reports temperature data relative to TJMax which is the safe maximum operating core temperature for the CPU. As your CPU heats up, your Distance to TJMax will decrease. If it reaches zero, your processor will start to thermal throttle or slow down so maximizing your distance away from TJMax will help your computer run at full speed and more reliably too.
Main Features- Reads temperature information from all Intel Core based processors. Pentium 4 processors are not supported.
- Ability to individually calibrate Real Temp for each core of your CPU.
- Program is based on temperature data gathered using a Fluke 62 IR Thermometer.
- Test Sensors feature will check your DTS sensors for any sign of problems.
- Keeps track of Minimum and Maximum temperatures with full logging features.
- Reporting and logging of the Intel PROCHOT# thermal throttle activity bit.
- Quick, very accurate and repeatable benchmark.
- Displays MHz, TJMax, CPUID, APIC ID and Calibration settings.
- High temperature alarm and shutdown feature based on CPU or Nvidia GPU temperature.
- No installation or registry modifications required.
- Support for Windows 2000 / XP / Vista / Windows 7 (32 & 64 bit)
RealTemp.exe
is this normal? Restorator 2007
By ミறѳѳղղįզվદ彡 in forum General QuestionsReplies: 8Last Post: April 8th, 2021, 05:00 PM -
7zip 920 Multilingual Normal & Silent
By 8pecxstudios in forum CompressionReplies: 6Last Post: October 1st, 2012, 01:10 AM -
start menu / all programs/all programs menu*normal static text location*
By error441 in forum Windows Style Builder v1.5 TutorialsReplies: 3Last Post: July 20th, 2012, 12:26 AM -
Start Orb won't change/go back to normal!
By Xeno Templar in forum Start OrbsReplies: 7Last Post: September 21st, 2011, 09:02 PM
