Thread: RealWorld Cursor Editor
October 11th, 2012 08:46 PM #1
What can this cursor maker do for you?
Create cursors from images
This is a standard function of every cursor maker. RealWorld Cursor Editor has a wizard for quick conversions and an integrated animation editor to deal with problematic images.
- Make cursors from PNG, JPG, BMP and GIF images.
- Select multiple images to create an animated cursors.
- Split filmstips to individual frames to make animations.
Make multi-resolution cursors
RealWorld Cursor Editor is the only tool capable of editing Windows 7 multi-resolution animated cursors. These cursors contain animation in multiple sizes and Windows 7 pick the right size depending on its DPI setting.
- Create multi-res cursors from images.
- Convert normal cursors to multi-res cursors and back.
- Apply effects to all frames and resolutions in a cursor.
Make animated cursors
Frames in animated cursors can be moved or copied using mouse or clipboard in an intuitive manner. Appending one animation to another is a matter of few seconds. The animated cursor editor allows running filters on all selected frames at once.
Setting frame duration is as easy as clicking on a frame, typing a number, and pressing Enter. Alternatively, duration of multiple frames can be changed at once using the Frame Duration panel.
Customize cursors
RealWorld Cursor Editor gives you two ways to quickly change your active cursors.
- Open a cursor and make it the active cursor for selected role from the Cursor menu.
- Drag and drop cursors on role panels on the Customize screen and click Apply all to change all roles at once..
S.Cursor RED
By serschik in forum CursorsReplies: 73Last Post: November 26th, 2022, 07:29 PM -
Win+X Menu Editor
By hb860 in forum Windows 10 Customization ToolsReplies: 3Last Post: May 26th, 2019, 02:07 AM -
Windows Seven Cursor from Serschik (S.Cursor)
By serschik in forum CursorsReplies: 29Last Post: June 3rd, 2014, 10:18 PM -
Blank editor.
By HammerJack in forum Requests, Site Problems and FeedbackReplies: 15Last Post: September 14th, 2013, 07:26 AM -
ORCA MSI Editor
By razorsedge in forum Silent install creator appsReplies: 0Last Post: July 22nd, 2012, 06:59 AM
