Thread: Gray8 beta
November 21st, 2012 08:20 PM #1
Gray8 beta
Here is my first Windows 8 theme
A little bit about the theme
I calling it beta because it is my first Windows 8 theme and I wasn't able to do my normal extra's this time.
Except for a clock-which is for 64 bit system's only.
Your system needs to be patched for 3rd party themes first
I'm using this patcher Windows 8 Ultra UXTheme Patcher - WinMatrix
There is other patchers available but they are known to cause issues when some other customizing softwares are also being used.
The theme it's self uses a modified version of Mr.Grim's Equinox msstyle,so if you have the extra's for that
theme installed things like the Control Panel images will change automatically when you switch to this theme.
There is no installer for this theme so you will have to copy the g8 beta folder and g8 beta.theme file to
your Windows Resources\Themes folder.
To change the clock navigate to Windows\System32 and find your timedate.cpl.Take full conrtol of this file and rename.
Then copy the new custom one I provided over.You will either have to restart Explorer or sign out before the clock will change.
Hope you guys like it!Enjoy!
The Start Menu is StartIsBack,the one from Stardock isn't 100% themeable
The icons used in the screenshots are Token by ~brsev on deviantART
And were applied using a combination of IconPackager and manually changing them.
The wallpaper is from here Windows 8 Wallpapers
The Rainmeter skins in the preview are My Stock Meters and Peeled by me
https://www.mediafire.com/?f6vz7d5fs1ftect
Gray8 Color Pac
By gsw953 in forum gsw953 - Windows 8 ThemesReplies: 18Last Post: September 17th, 2023, 04:16 PM -
Gray8.1 Glass
By gsw953 in forum gsw953 - Windows 8 ThemesReplies: 34Last Post: February 20th, 2020, 12:13 PM -
Gray8 for Windows 7
By gsw953 in forum gsw953's Windows 7 ThemesReplies: 7Last Post: February 25th, 2019, 09:38 AM -
Gray8 Blue High Contrast mode
By gsw953 in forum gsw953 - Windows 8 ThemesReplies: 13Last Post: August 23rd, 2014, 03:57 PM -
Gray8-light
By gsw953 in forum gsw953 - Windows 8 ThemesReplies: 6Last Post: December 21st, 2013, 05:37 PM
ROG Tweak Theme for...
