December 8th, 2012 03:37 AM #1
How To Enable/Disable Fast Startup In Windows 8
Microsoft’s latest Windows 8 operating system has been designed for delivering better speeds than previous versions of Windows. Because of this, Windows 8 is faster in almost every department compared to its predecessors. It boots faster, takes less time to copy or move files, and finally it’s low on system resources as well.
With the introduction of Windows 8 Microsoft has introduced a new feature named Fast Startup. According to Microsoft, only a small amount of Windows users use the hibernate feature and the Fast Startup helps users who prefers to shutdown the PC rather than hibernate it. Because of this feature, Windows 8 boots in less than six seconds on a solid state drive (SSD).Fast startup is a setting in Windows 8 that helps your PC start up faster after shutdown. Windows does this by saving system info to a file upon shutdown. When you start your PC again, Windows 8 uses that system info to rescue your PC instead of restarting it.
Please note that the fast startup setting doesn’t apply to restart. You need to shutdown and then start your PC again for fast startup to take effect. We recommend you check out this page of the official Windows 8 blog to know about the feature in detail.
Even though the fast startup feature is turned on by default in Windows 8, you may want to make sure that the feature is enabled. Follow the given below steps to enable or disable the feature.
Step 1: Switch to the Start screen. Press Windows + W keys to see the search charm, type Power Options and press enter key to open Power Options window.
Step 2: In the left pane of Power Options window, click Choose what the power buttons do.
Step 3: Here, click on Change settings that are currently unavailable. Next, under Shutdown settings, tick Turn on fast startup (recommended) checkbox to enable the feature. Finally click Save changes button. You are done!
article page: https://www.intowindows.com/enabledis...-in-windows-8/
Startup Sound Changer is the easiest way to change the startup sound in Windows 7
By hb860 in forum Windows 7 Customization ToolsReplies: 2Last Post: November 23rd, 2013, 01:33 PM -
How To Enable Or Disable Touchpad Gestures In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:15 AM -
How do Disable the annoying Windows 7 startup repair
By odinlives in forum Installation & SetupReplies: 0Last Post: February 10th, 2011, 07:13 PM -
Enable or disable CTRL+ALT+DELETE sequence for logging on to
By razorsedge in forum News & ReviewsReplies: 0Last Post: September 2nd, 2010, 07:15 PM -
Disable and re-enable hibernation in Windows using Microsoft
By razorsedge in forum Setup TutorialsReplies: 0Last Post: August 23rd, 2010, 01:18 PM
