December 8th, 2012 04:04 AM #1
How To Disable Lock Screen In Windows 8
Method 1: Works on Windows 8 Pro and Enterprise editions only.
Step 1: Switch to desktop. Press Windows + R keys to see the Run dialog. In the box, type gpedit.msc and then press enter key to open Group Policy Editor.
Step 2: Once launched, navigate to Computer Configuration, Administrative Templates, Control Panel, and finally Personalization.
Step 3: Double-click on the option named Do not display the lock screen to see its properties.
Step 4: Here, select Enabled and click Apply button. You are done!
Method 2: Works on all Windows 8 editions except Windows RT.
Step 1: Open Registry Editor. To do this, open Run dialog box (use Windows + R keys to open Run dialog), type Regedit.exe and then press enter key. Click Yes for the UAC prompt.
Step 3: Look for Personalization key under CurrentVersion, and if doesn’t exist, create Personalization key.
Step 4: Now, on the right-hand side of Personalization, create a new DWORD value named NoLockScreen. Once done, double-click on NoLockScreen and set its value to 1 to disable the lock screen and 0 to enable the lock screen. Close Registry Editor. You are done!
article page: https://www.intowindows.com/how-to-di...-in-windows-8/
Remove windows lock screen and change logon screen background in rs1?
By Wolfy in forum Windows 10 Theme Help and SupportReplies: 5Last Post: December 22nd, 2017, 05:30 AM -
Windows 10 rs1 lock screen won't disable and titlebar color resets
By Wolfy in forum Windows 10 Theme Help and SupportReplies: 30Last Post: October 16th, 2016, 04:57 AM -
Windows 8.1 wallpaper / start screen / lock screens
By Dark Knight in forum Wallpapers Posted by Dark KnightReplies: 1Last Post: July 19th, 2014, 12:50 PM -
IM Lockscreen slide show Rotate Windows 8 Lock Screen Background With IM Lock Screen
By razorsedge in forum Windows 8 AppsReplies: 0Last Post: December 8th, 2012, 02:39 AM -
Chameleon: Add Custom Backgrounds to the Windows 8 Lock Screen
By razorsedge in forum Windows 8 AppsReplies: 0Last Post: December 7th, 2012, 02:58 AM
From DA: https://www.deviantart.com/niivu/art/macOS-for-Windows-11-952231551
Is there a good Mac...
