Thread: Poison Windows 8 Theme
February 9th, 2013 05:57 AM #1
OK guys here it is, one of the old good ones from 7, changed a few bits just to make it look better on 8
Some of the things you see in the screen are only possible if you are using the modified files I provided for the Equinox beta theme and to have the start menu you will need to purchase StartIsBack if you want to have aero enabled on the frames then you will have to use WinaeroGlass or a new experimental version Aero Glass for Win8 currently at version 0.3 and not intended for everyday use and is very unstable at the moment.
I have only done a small amount of testing on this theme so there may still be some bugs, if you find any problems then please let me know and I will try to fix them for you.
I am still using UXStyle core beta for Windows 8 to be able to use custom themes, the last patched theme files seems to cause problems after windows updates but that problem may have been resolved now, but regardless make sure you have enabled custom themes as always or they will not work.
Also if you modify my theme at all then please make sure you always keep the shell folder with it as it contains a modified shellstyle.dll that can only work with the extra properties I have added to the theme, if the theme is used with another shellstyle.dll it will not work and result in blank explorer windows.
Aero Glass installer all in one for 32bit and 64bit OS, includes AGTweaker (ORelio) (Mod Tusticles)
NOTEAdded reg file for Window Metrics (Not applied to custom Themes on Windows 8) Last edited by Mr GRiM; August 11th, 2013 at 03:44 PM.
theme poison
By NH29950 in forum General Windows 11 CustomizationReplies: 0Last Post: March 8th, 2023, 08:45 AM -
Poison Red Theme with Poison iPack
By ミறѳѳղղįզվદ彡 in forum Themes by Mr GRiMReplies: 10Last Post: January 6th, 2019, 09:08 PM -
thème poison for windows 10 .1709
By Ray061630 in forum News & ReviewsReplies: 7Last Post: November 1st, 2017, 07:27 PM -
Thème Poison et windows 10 .1709
By Ray061630 in forum Windows 10 Theme Help and SupportReplies: 0Last Post: October 22nd, 2017, 06:33 PM -
Poison Theme for Windows 8.1
By Mr GRiM in forum Mr GRiM's Windows 8 ThemesReplies: 155Last Post: December 26th, 2015, 10:05 AM
