Hey everyone,here is a Chameleon style theme for Windows 8
Just like the Win 7 version you will be able to change the main Explorer
background,Start Menu(StartIsBack),Taskbar and a few other things
by simply adjusting the color from the Control Panel\Personalize\Color window!
The theme will load as a black theme,if you run Areo Glass for Win8 v0.3
and Black Glass Enhanced you will get full transparency with blur.
Now if you go to Control Panel\Personalize\Color you can choose a new color.The stock Windows colors
are pretty light so you will probably need to open the Advanced Mixer and adjust the color.
If you don't want transparency but still want a custom color turn off Aero Glass but leave Black Glass Enhanced on.
You will notice some items in the Ribbons didn't get themed or aren't transparent,so I normally use Ribbon Disabler
and go back to the Win 7 style no ribbon.
I also included some 64 bit system files,for the clock,wmp12,etc
The wmploc.dll files gives your WMP the same abilities as the theme that is it will also
change color and be transparent if you want.
I think that's it-instructions,previews and links are included in the download
Chameleon for 8-v2
