Thread: Ultimate Clean 8 updated
April 20th, 2013 04:15 PM #1
I had a request to add caption buttons back into this theme
so I took the opportunity to do a few more updates.
The Ribbon background is now black and I added a skull to the
Explorer background.For this to show up you will have to use the
included ExplorerFrame.dll's(64 bit only).These have been test on several
installs but Windows 8 can be a bit finicky when changing system files
so make sure you have a backup BEFORE trying to change them.
Just in case something goes wrong.Also if you use Ribbon Disabler you will need to
re-enable the ribbon before changing the ExplorerFrame.dll's.You can disable it again
after you change them and have restarted your system.
The other new option is Ultimate Clean High Contrast mode.
If you were a dark theme user on Windows 7 you will already know that sometime you
will encounter black text on black backgrounds.
Switching to the high contrast mode seem to fix this.If you have this set up properly
you will be able to quickly switch between normal high contrast mode with a keyboard shortcut
Instructions on this are included.The high contrast theme is very usable on it's own,the main difference
is the Start Page is black with no image,you don't need to change the shell32.dll to have black control panel images
and some programs will have basic buttons and scrollbars.
I have stopped including the shell32.dll's in the theme download.
The reason for this is because Microsoft has been updating it monthly,so I
think it is easy just to provide a link to my current version instead of having
to update all my themes monthly
So here is the link to the newest version I have-1654748(64 bit only)
Ultimate Clean version 2
Ultimate Clean 4
By gsw953 in forum gsw953's Windows 7 ThemesReplies: 26Last Post: September 16th, 2021, 10:28 AM -
Ultimate Clean 8
By gsw953 in forum gsw953 - Windows 8 ThemesReplies: 13Last Post: February 9th, 2018, 07:05 AM -
Ultimate Clean for 10
By gsw953 in forum Themes by gsw953Replies: 38Last Post: November 29th, 2015, 01:38 PM -
Ultimate Clean V2
By gsw953 in forum gsw953's Windows 7 ThemesReplies: 38Last Post: December 20th, 2014, 08:01 AM -
Ultimate Clean version 3
By gsw953 in forum gsw953's Windows 7 ThemesReplies: 32Last Post: March 3rd, 2014, 02:46 PM
