Thread: Help please for my windows 8
June 14th, 2013 09:50 AM #7
- Jul 2012
- pisa
- 333
- 325 Thread(s)
I re had the problem before was looked past every 10 minutes after maintenance as above and resurfaced every 30 minutes then I had another job I downloaded a soft interesting to try x if all you want is called (refresh-pc) is currently not I still have the problem emerges if the interference in the system vo'll keep updated ok. climbed max68
RefreshPC 2.0 Reset your PC's settings safely and easily. RefreshPC is a utility to return select registry settings and all Windows services to their default state.This can fix many problems with your computer.RefreshPC is a very easy to use and safe utility for fixing misconfigurations in your services and in the registry itself.RefreshPC will do the following:
- Reduce errors in the Event Viewer
- Fix service misconfigurations that may be causing problems including slow boots.
- Clean your temporary folders.
- Reset key registry entries back to their default values.
The best part is it is Freeware.RefreshPC works on Windows XP, Windows Vista, Windows 7 and Windows 8. 64bit and 32bit versions.
refreshpcinstall.exe
Windows 7, Windows 8, Windows 10 TH2 import to Windows 10 19H1 1903
By Mr GRiM in forum Updates & Style Hacks For WSBReplies: 29Last Post: September 2nd, 2021, 10:04 PM -
Start9: Windows 10 Preview/Windows RT/Windows 10 Start Menu for Windows Vista and up!
By Splitwirez in forum Members Software DevelopementReplies: 15Last Post: July 28th, 2018, 08:27 PM -
Windows 10, Windows 8.1, Windows 7 & Windows XP Game Ready Driver Released
By Feed Monkey in forum GeForce.comReplies: 0Last Post: July 31st, 2015, 07:07 AM
Windows 11 24H2 OS Build 26100 https://virtualcustoms.net/showthread.php/88844-Windows-11-24H2-OS-Build-26100
