Thread: Login Screen Capture
June 15th, 2013 04:16 AM #1XxHackThisxXGuest
I dont know if this is in here or not but i thought i would post it.I know some of you are wondering how to capture your login screen.I use "Login Screen Capture" which is very simple to install.Login Screen Capture 7 is a , accessible and handy software that allows you to easily capture your Windows 7 login screen.
In order to use the you need to:
· Open up \Windows\System32
· Look for a file called "Utilman.exe"
· Take ownership the "Utilman.exe" file, and rename it into "Utilman_old.exe"
· Copy the new "Utilman.exe" file that is located in this folder to Windows\System32
· Lock Windows 7, and click on the Ease of Access button.
· Capture the logon screen with ease.
If you dont know how to take ownership of a file then i will show you.
1.right click the file that you want to take ownership of and click on "properties".
2.A box will appear.At the top,click on the "security" tab.
3.After clicking on the security tab,near the bottom,click the "advanced" button.
4.Another box will pop up.At the top of that box,click on the "Owner" tab.
5.At the bottom of that box,click on the "Edit" button.
6.In the box that appears next,go to where it says "Change owner too:",and click on the appropriate name,usually the one with "Administrator" by it,and then click apply
7.exit the file and then rename it.
Here is the download url that i used..https://www.softpedia.com/get/Multime...apture-7.shtml
Thats it.Enjoy
Multiple Login Screen (12 images)
By Ryuugahideki28 in forum Log On ScreensReplies: 2Last Post: June 23rd, 2020, 08:43 PM -
can you modify windows login screen?
By justin2556 in forum General Windows 8 CustomizationReplies: 3Last Post: May 31st, 2013, 12:01 AM -
screen capture
By deviantdon in forum Chill Out RoomReplies: 23Last Post: April 11th, 2013, 04:14 PM -
Logon Screen Capture
By Big V in forum GraphicsReplies: 9Last Post: October 21st, 2011, 04:07 PM -
DuckLink Screen Capture
By razorsedge in forum GraphicsReplies: 0Last Post: August 15th, 2010, 08:31 AM
