Thread: Gray 8.1
November 24th, 2013 02:24 PM #1
Gray 8.1
Hey Everyone,I was dying to check out Mr.Grim's new Custom Class Maps
So I dropped everything yesterday and did an update to Gray8 for 8.1!
This updated is made to be used with OldNewExplorer by Tihiy
When using this app,you will be able to disable the Ribbon add the old Details Pane and have the custom images for the
Control Panel and System Properties load.Plus a few more things
I have also included the clock for Gray8-updated to work on 8.1
a new dark WMP12 skin
and a Token small 7tsp icon pack that will work on 8.1
I am no longer using StartIsBack so this theme was designed NOT to be used with it.
It should still work fine if you have it installedd but the Taskbar icon right click menu may not look 100%
A huge thanks to Mr.Grim and Tihiy for making this possible!
I did play around with the shellstylle.dll a bit and added a hover text color to the Command bar
and the Explorer Listview items!
Your system must be patched to run 3rd party themes
Instructions,previews and credits are included
gr8.1-2.zipLast edited by gsw953; November 25th, 2013 at 12:02 AM.
Spectral Gray
By devillnside in forum Themes by devillnsideReplies: 13Last Post: May 12th, 2020, 03:52 PM -
The gray veil
By Erdenhengst in forum Theme IssuesReplies: 12Last Post: May 1st, 2020, 01:50 PM -
Gray
By mauam in forum CursorsReplies: 3Last Post: November 11th, 2011, 10:13 PM -
Gray Ice
By ミறѳѳղղįզվદ彡 in forum Moonnique's Posted ThemesReplies: 0Last Post: November 20th, 2010, 11:05 PM -
Gray Side
By Psych0t1c in forum Miscellaneous questionsReplies: 7Last Post: July 11th, 2010, 02:50 PM
