January 26th, 2014 09:25 PM #1
- Sep 2013
- UK
- 387
- 123 Thread(s)
Avoid accidental and automatic shut down or restart with ShutdownGuard
Microsoft has always allowed applications to shut down or restart Windows programmatically. Installers of various desktop apps, or the apps themselves as well as various Windows components such as Windows Update can automatically shut down or restart your PC on demand or on a schedule. If you do not like this behavior, thankfully, Windows has a way to avoid it. Using a simple, third party tool called ShutdownGuard, we can stop automatic shutdown, restart, and logoff without affecting manual ways to do it.
Microsoft provides an API in the OS which applications can use to delay or veto a shut down, restart or log off. It is necessary to have this ability because while doing certain actions on your PC such as when burning an optical disc or when downloading files, it is imperative that your PC doesn't exit Windows suddenly. The application called ShutdownGuard uses this API to prevent shut down when some program calls for it.
1> Download and install ShutdownGuard During the installation, check the option to Autostart.
Here's download link
2> Allow the installer to open ShutdownGuard or start it manually. It will place its icon in the notification area (system tray). The icon may also be hidden inside the overflow area. In that case, click the tiny arrow to show it.
3> Right click the ShutdownGuard to access its settings. You can hide its tray icon (not recommended), disable it, or configure options such as Autostart.
4> It has advanced settings in an INI file called C:\Program Files\ShutdownGuard\ShutdownGuard.ini. If you have User Account Control (UAC) set to the highest level, you may need to open this file as administrator to save changes to it. By editing the INI in Notepad or another text editor, you can customize the text message it shows when a shutdown is blocked, and some other options.
5> When ShutdownGuard is running and the tray icon is "locked", every time Windows, or some app or the user attempts a restart or shutdown, the following message will be shown by Windows:
You can click here "Shut down anyway" or "Restart anyway" to continue shutting down. However, this will forcibly terminate all apps. This screen will show you all running applications. If you have unsaved work, you can click Cancel which will take you back to the Desktop. There you can close apps properly, save your work and then safely continue with the Shutdown.
6> To allow a shut down, just left click once on the ShutdownGuard icon in the notification area so it "unlocks" shut down. Now when you try manual shut down/restart or log off or when some app attempts it, it won't be blocked.
That's it. Now you can know how to avoid most of those unexpected and untimely reboots. It is important to note that ShutdownGuard is not 100% foolproof. Windows or apps still have the ability to override it if they force the shutdown. ShutdownGuard just gives you an opportunity to save your work in open windows and avoid unexpected restarts which are automatically initiated by installers or apps.
ShutdownGuard is made by the developer, Stefan Sundin. It is a free app but accepts donations.
(Instructions by Sergei from Winaero)
Restart/Shutdown/Log off Buttons
By HungryHippo in forum RequestsReplies: 4Last Post: March 8th, 2012, 12:12 PM -
RightClick Restart Explorer by ~LeeWhittington
By razorsedge in forum MenusReplies: 6Last Post: October 29th, 2011, 10:23 AM -
Internet Explorer 9 RC Available Via Automatic Update
By razorsedge in forum News & ReviewsReplies: 0Last Post: February 17th, 2011, 02:06 AM -
How to swap out explorer.exe on restart
By crabdance in forum OS & Hardware Help and SupportReplies: 7Last Post: December 23rd, 2009, 01:49 AM
