June 3rd, 2014 01:10 PM #1
- Nov 2010
- 2,938
- 451 Thread(s)
Windows 8 Task Manager For Windows 7
This post will tell you how can you use windows 8 task manager in windows 7.A proram name
DBC task manager which same as windows 8 task manager,i will tell you how to replace this
windows 7 task manager with windows 8 default task manager.
FOLLOW THESE STEPS:
Extract the archived .exe file to its own folder, preferably in the Program Files folder.
Now go to run and type "regedit" then enter
Navigate to:
“HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\taskmgr.exe
Select the taskmgr.exe key and create a new string value on the right side panel.
Now rename the new value to DEBUGGER
Right click on the new “Debugger” string and select “Modify”. Enter the full address of the new task
manager program. This will basically make the new task manager start instead of the old one. This
can be done for any program, by the way – it’s a nice little known trick in Windows.
Now you will see the new task manager anytime you press CTRL-ALT-DEL and click “Start Task Manager”
or when starting from anywhere else. To revert to the old task manager, you just need to delete the
“taskmgr.exe” key from the registry – pretty easy!
DOWNLOAD LINK:
https://www.mediafire.com/download/2526if5ckm955z3/DBCTaskmanx86.zip
Task Manager Windows 11 22h2
By tistou77 in forum Help & Support, RequestsReplies: 7Last Post: May 1st, 2024, 02:06 PM -
Need the task manager skin for the windows 8.1 version of the theme A Thin White Line
By Nimbi in forum RequestsReplies: 2Last Post: September 24th, 2014, 03:36 PM -
Help finding Windows Task Manager Text at bottom
By grunt3 in forum Text Color LocationsReplies: 1Last Post: July 30th, 2013, 01:37 PM -
Windows Task Manager & System Properties
By RBCC in forum Help & SupportReplies: 1Last Post: April 21st, 2011, 08:55 AM -
Customized Task Manager for Windows 7
By razorsedge in forum MiscellaneousReplies: 0Last Post: December 10th, 2010, 11:42 PM
