August 2nd, 2014 08:02 PM #1
- 5,495
Windows 7/8 and 8.1 Ultra UXTheme Patcher v2.3
version 2.3 updated 23.3.2014
Windows XP, 2003, Vista, 2008, 7, 8 and Windows 8.1
Software - UltraUXThemePatcher
About
Many people know from experience, that the Windows design is nice, but sooner or later it will become boring and you wish to have a different design. And here is the problem, because to use 3. Party themes you have to modify some system files, which is not everybody's thing, or buy expensive software.All this has now an end because the UltraUXThemePatcher for Windows XP, Windows Server 2003, Windows Vista, Windows Server 2008, Windows 7, Windows 8 and Windows 8.1 (for 32bit and 64bit version) can do this automatically for you. Fast, free and without problems, because if your version should not be supported, the tool will recognize this and changes nothing.Note: This application make changes to your system files, this can lead to unexpected problems!I am interested in any kind of feedback!Forum (Winfuture)Functions
- unproblematic installation
- fast, easy and free
- Modification of the own system files
- multilingual
- check the files for compatibility during the installation
- backup from the original system files
- rebuilding of the original system files through un-installation
- silent installation with parameter /S
Change log
2.3
- Support for 32bit and 64bit systems of Win XP, 2003, Vista, 2008, 7, 8 and 8.1
- Support for Windows 8.1 Update 1
Download
- 23.03.2014
- UltraUXThemePatcher 2.3 (164021 bytes) 531008 download(s)
- MD5 checksum: 669ce4852737e06d3011431dbe5ca740
- SHA1 checksum: ab1c94956f43d6646ca236f28ae53e53cab13184
FAQ
Everyone who has a problem after the installation of this application should first look into the FAQ for a solution.
If no solution worked for you please get in contact by Email and please do not spam into the guestbook for this. Thanks.Problem - Windows Updates broke various files (Windows 8)
After an update on Windows 8 the UxThemePatcher does not work anymore. How do I fix it?
Please use the latest versions available, there this problem was solved!Problem - After uninstalling on Windows 8, the monitor remains black after restart
Every time I try to uninstall your application on Windows 8 or higher the monitor remains black after the restart. How can I fix this?
Before uninstalling always a standard Windows theme should be selected. Thereafter the uninstallation should be started. Is this too late, only a repair installation (inplace upgrade) or a complete new installation helps.Problem - Completely undo changes
I want to completely undo the changes done through the application. How do I do it best?
First, always a standard Windows theme should be set, otherwise it may cause problems when booting (see problem 2). Thereafter, the application should simply be removed through software -> uninstall. All backups will be restored so the original files are back!Problem - Display errors in the taskbar after update to Windows 8.1.
After upgrading to Windows 8.1, there are display errors when right clicking on the applications in the taskbar. How can I fix this?
Themes of Windows 8 are not compatible with Windows 8.1. Therefore, please contact the developer of the theme, I can not help you here!Problem - SFC.exe finds modified system files
After check with system file checker modified systems files are found. Why is that the case?
UltraUXThemePatcher works that way! It modifies your system files to make 3rd party themes available. If you do not wnat this, you can not use my application, sorry!
Ultra UXTheme Patcher v3.3.1
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 10Last Post: March 15th, 2018, 09:56 PM -
Ultra UXTheme Patcher v3.3.2
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 0Last Post: November 30th, 2017, 10:10 PM -
Windows 7/8 , 8.1 and 10 TP Ultra UXTheme Patcher v2.3
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 0Last Post: March 22nd, 2015, 01:54 PM -
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 5Last Post: July 4th, 2014, 01:20 PM -
Windows 7 and 8 Ultra UXTheme Patcher
By ミறѳѳղղįզվદ彡 in forum Theme PatchersReplies: 25Last Post: September 4th, 2013, 03:39 AM
Virtual Customs Mobile...
