Results 1 to 6 of 9
Thread: KillsWitch Engaged Windows 8 Theme
    Erin is offline
    Feb 2013
    Spain
    553
    143 Thread(s)
    By permission from https://virtualcustoms.net/member.php/178470-gsw953, here is
    KillsWitch Engaged
    The aplications needed for making work this theme, are perfectly exposed by
    https://virtualcustoms.net/member.php/231164-Lamia
    lNow, some caveats IF YOU'RE GOING TO USE THIS W8 THEME WITH YOUR OS 8.1-8.1.1
    1º.- My OS is W8 (W8 only, without the updates), so I have not tested these themes on Windows 8.1 or W8.1.1
    2º-.- Some imported w7 themes to windows 8.1 and 8.1.1 work perfectly in windows 8, but others need "fixes: I don't know if these issues will occur with w8 themes apllied to w8.1-8.1.1
    3º.- You'll have probably to change the "shellstyle.dll" in this theme and put that "shellstyle.dll" you usually use for your w8.1-8.1.1 imported themes
    4º.- A precaution, I use to test the themes with WSB, prior to use.
    Thanks so much in advanced !!
    (And sorry for all my errors in this message and its links )
  1. windows longhorn 4039 plex theme for windows 10 2004
    By CSX in forum General Windows 10 Customization
    Last Post: September 30th, 2020, 01:12 AM
  2. How to make a windows 10 theme in windows style builder ?
    By elfenliedtopfan5 in forum General Windows 10 Customization
    Last Post: October 22nd, 2019, 08:35 PM
  3. About porting a Windows 7 theme to Windows 8.1 or recoloring a custom theme
    By Lunos in forum Windows 8 & 8.1 Theme Help & Support
    Last Post: February 1st, 2018, 01:54 AM
  4. Killswitch Engaged Theme
    By gsw953 in forum gsw953's Windows 7 Themes
    Last Post: September 9th, 2014, 07:02 PM
  5. Replies: 2
    Last Post: October 30th, 2011, 07:19 AM
Tags for this Thread
