Thread: Windows 7 Logon Screen Rotator
September 24th, 2014 05:31 PM #1
- Nov 2010
- 2,938
- 451 Thread(s)
Rotate Windows 7 Logon Screen With Windows 7 Logon Screen
Rotator (Now Supports Any Number Of Images)
admin Updated on Jan 16th, 2014
We’ve posted about Windows 7 logon changer utility and also about manual way to change Windows 7 logon screen easily without the help of third-party applications in the past.
While most of the logon screen utilities let you change Windows 7 logon screen easily, here is a unique application that changes the logon screen each time you login or any specified time interval (see below). That is, you will see a new logon screen each time you login to Windows 7.
Logon Screen Rotator lets you add as many as images you like of any size and resolution. If the image size is not less than 256 KB (this is the max allowed size for windows 7 logon background image) the image will be resized automatically. Another advantage is that it lets you add as many as images folders as well.
User can also choose when the logon screen should be changed from the available three options: Every logon, Every day, Every (specified) hour. With these options Windows 7 logon screen rotator outperforms other logon changers. If you wish, you can easily revert to the default logon screen by using revert to default Windows logon screen option under Settings tab. The Logon Screen Rotator is a standalone (no need to install) utility and can be downloaded from the link given below.
DOWNLOAD LINK:
https://www.brothersoft.com/logon-scr...67.html?bottom
Windows 7 logon screen 2
By Robbo in forum Log On ScreensReplies: 1Last Post: August 1st, 2020, 04:25 PM -
By Robbo in forum Log On ScreensReplies: 2Last Post: August 1st, 2020, 04:24 PM -
Remove windows lock screen and change logon screen background in rs1?
By Wolfy in forum Windows 10 Theme Help and SupportReplies: 5Last Post: December 22nd, 2017, 05:30 AM -
Logon WorkShop: Advanced Logon Screen Tweaker For Windows 7
By razorsedge in forum LogonReplies: 14Last Post: December 1st, 2013, 08:42 PM -
By razorsedge in forum LogonReplies: 0Last Post: January 13th, 2011, 11:53 PM
