Page 2 of 3 FirstFirst 123 LastLast
Results 7 to 12 of 18
Thread: Unable to patch system files with Windowblinds 8 installed ? Share
    Ghost Rider is offline
    Jan 2013
    Hell Street
    118
    1 Thread(s)
    Hi guys, a couple of days ago I restored system files and installed Windowblinds 8, just to give it a try. Now I want to patch system files again, but it looks no possible after restart I'm unable to access Windows. So I need to boot in safe mode, restore system files and restart again.
    I guess I have to uninstall Windowblinds 8 to get everything working fine, even if Windowblind 8 is not loaded and no skin is applied to access Windows with patched files is not possible.
    Anyone knows if there is a way to patch system files (Universal Theme Patcher)and keep Windowblinds 8 installed ?
    Thanks
  2. #7
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,795
    152 Thread(s)
    Thanks One Man Army. I did an sfc/scannow about a week ago, but didn't repatch with Uxstyle. I'll do that and hopefully it works.
  3. #8
    Jan 2013
    Hell Street
    118
    1 Thread(s)
    Thanks all but I think MOST_WANTED is right, it's not possible to use "Windowblinds" and "3rd party customization" at the same time. A choice is required, one or another
  4. #9
    ONE MAN ARMY is offline
    Super Moderator
    Apr 2011
    San Diego California
    34
    1,230
    570 Thread(s)
    Ya. I would just run the scan and then repatch and see if that fixes the issue. I have a feeling windows blinds changed something in your system that is conflicting with your ability to use themes. Its always safe to just run the SFC /scannow and try fresh. Hope it helps.
  5. #10
    Moderator
    Aug 2014
    Ontario, Canada
    1,795
    152 Thread(s)
    Quote Originally Posted by ONE MAN ARMY View Post
    Open Command Prompt as admin, Type SFC /scannow Wait for the scan to finish. Reboot your comp. then repaatch your system with uxstyle. Apply theme.
    So, I did what you instructed. Ran the sfc/scannow as admin, rebooted when prompted, uninstalled Uxstyle, then reinstalled after rebooting again. I'm still getting the error where after going from shut down I can't change the themes. One thing to note is that I haven't installed windowblinds, just have windowfx from stardock, sorry for not clarifying that.
  6. #11
    Super Moderator
    Apr 2011
    34
    1,230
    570 Thread(s)
    Well. Not sure whats going on my friend. Hopefully someone has the answer. If it was me in your position. I would just backup everything I wanted on a External HD and Then do a clean install and start fresh. Not sure if this is an option for you. I tend to keep everything important on my external anyway. So doing clean install for me is pretty simple. Be patient though. Grim was tagged in this thread so hopefully he will come on soon and have an answer for you. Sorry I was not able to help.
  7. #12
    idle is offline
    Feb 2013
    Au
    121
    29 Thread(s)
    The way I was able to change themes was first change the metric.reg file by using Default Windows 8.1 Aero Metrics.reg (which should always be in the EXTRAS folder of any theme you download from this site) Then select a Windows Default Theme in Personalize. Let that theme load, and reboot system. Once reboot finish, go to Personalize again and select a different theme. This is the process I must use in order to change themes in Windows 8.
    Hope it works for you.
  1. Replies: 6
    Last Post: 12-17-2013, 02:49 PM
  2. Replies: 0
    Last Post: 03-01-2011, 07:09 AM
  3. How to patch your theme files to enable 3rd party themes
    By razorsedge in forum Windows 7 Theme Help & Support
    Last Post: 11-16-2010, 05:04 AM
  4. Take Ownership of System Files (How do I do It)
    By Mercohaulic in forum General Questions
    Last Post: 08-27-2010, 06:42 AM
