Page 1 of 3 123 LastLast
Results 1 to 6 of 18
Thread: Unable to patch system files with Windowblinds 8 installed ? Share
    Ghost Rider is offline
    Jan 2013
    Hell Street
    118
    1 Thread(s)
    Hi guys, a couple of days ago I restored system files and installed Windowblinds 8, just to give it a try. Now I want to patch system files again, but it looks no possible after restart I'm unable to access Windows. So I need to boot in safe mode, restore system files and restart again.
    I guess I have to uninstall Windowblinds 8 to get everything working fine, even if Windowblind 8 is not loaded and no skin is applied to access Windows with patched files is not possible.
    Anyone knows if there is a way to patch system files (Universal Theme Patcher)and keep Windowblinds 8 installed ?
    Thanks
    2635599 is offline
    Banned
    Nov 2010
    54
    3,065
    451 Thread(s)
    Ghost Rider i'm going to go out on a limb here and say i think your problem might be that wb8 has to patch the system in it's own way to allow it's themes to work. if this is the case i would think you would have problems using uxthemepatcher. now what grim uses uxstyle might work better for you. i'll tag a couple of peeps to see what they think.
    ONE MAN ARMY is offline
    Super Moderator
    Apr 2011
    San Diego California
    34
    1,230
    570 Thread(s)
    Ya not sure either. I never use Windows Blinds. But if I was in your position. I would open cmd as admin run SFC /scannow
    let that scan after its done reboot. Then repatch your system using uxstyle Like Dude the Nude Said and Try that. Running that scan should set all your system files back to Default so it will give you a fresh start.
    MOST_WASTED is offline
    Jan 2012
    las vegas, NV
    745
    1 Post(s)
    252 Thread(s)
    windowblinds has its own stuff that conflicts with other 3rd party customizations. in my win 7 i had to choose to either use "windowsblinds" or "3rd party tools patches and themes found in here". keep one, uninstall the other
    so i would recommend u remove your windowsblinds before repatching your windows
    Shemhamforash is offline
    Moderator
    Aug 2014
    Ontario, Canada
    1,848
    152 Thread(s)
    I don't mean to derail the thread, but I have a question about Uxstyle, so it's kind of related. I've noticed that since I changed from Ultraux back to Uxstyle, that on boot I can't change the themes. It's similar to Idle's problem where he had the theme files in the proper position, but the other theme stays on (for me, just the wallpaper and sound scheme changes). After booting up from shut down this happens, if I do a reboot, the themes change properly. It doesn't work to change to default theme before applying a custom theme. I installed Uxstyle a while ago, before updating to 8.1. Is it a good idea to reinstall Uxstyle, and is it safe to uninstall and reboot to Windows in default theme with custom themes still in Windows\Resources?
    Super Moderator
    Apr 2011
    34
    1,230
    570 Thread(s)
    Open Command Prompt as admin, Type SFC /scannow Wait for the scan to finish. Reboot your comp. then repaatch your system with uxstyle. Apply theme.
  1. How to patch your theme files to enable 3rd party themes
    By razorsedge in forum Windows 7 Theme Help & Support
    Last Post: 01-26-2018, 03:00 AM
  2. Replies: 6
    Last Post: 12-17-2013, 01:49 PM
  3. Replies: 0
    Last Post: 03-01-2011, 06:09 AM
  4. Take Ownership of System Files (How do I do It)
    By Mercohaulic in forum General Questions
    Last Post: 08-27-2010, 05:42 AM
