Thread: CustomizerGod by Kishan-Bagaria
April 15th, 2015 10:55 PM #1
- Jul 2011
- Nowhere
- 947
- 10 Thread(s)
NOTESome of you may know about this release already, but I thought it might be useful to post the info and link here, in the 'Customization Tools' section, regarding this cool tool for 7 and 8.1.
I actually can't believe no one has posted this news here at VC yet!
CustomizerGod is the ultimate tool for customizing Windows. It will completely change your customization experience forever.
Now, even total noobs can edit Windows system-files with ease!
Changing Resources:
First click and navigate the tabs in the left-hand pane and find what you want to change.
To change a single resource:
Click the resource in the right-hand pane.
Click Change.
Browse for the new resource and click Open. You can open any .png, .jpg, .ico, .gif or .bmp file and the file will be automatically converted to the required format.
To change multiple resources at once:
Select multiple resources by holding the Ctrl or Shift key. To select all resources, click anywhere in the right-hand pane and press Ctrl + A.
Click Change.
Browse for a directory containing the new resources in .png, .jpg, .ico, .gif or .bmp format. The filenames of the new resources should be the IDs of the resources (optionally starting with the # character, like #123.bmp). Move your mouse cursor (hover) over any resource in the right-hand pane to find its ID (if a resource has multiple IDs, use the first one).
Restoring Resources:
Just select the resources you want to restore in the right-hand pane and click Restore.
Customizing Other System & 3rd-Party Files:
Press Ctrl + O, browse for the new file and click Open.
CustomizerGod will list all the bitmaps and icons embedded in the file. When you open any file, a .backup file will be saved in the directory of the original file. Don't delete it until the app is closed.
Shortcuts & Advanced Options:
Click the little arrow in the bottom right corner to expand the window with more options. Hover over any option to find out what it does.
Resource Preview:
Double-click any resource in the right-hand pane to preview all versions of itself. Hover over any image to find out its dimensions.
Converting 3rd Party Resources:
CustomizerGod comes with a Resource Converter which can extract/rename existing 3rd party resources for use with CustomizerGod.
Rename ResHack RC File Resources: Open a .rc file saved by Resource Hacker and the resources saved along with it will be renamed to CustomizerGod-supported names.
Extract Resources from RES File: Open a .res file and all embedded resources will be extracted with proper names to the directory of the .res file.
Extract Resources from iPack: Open an iPack .exe and all embedded resources will be extracted with proper names to the directory of the iPack. This is not just limited to iPacks, you can also use this option to extract resources from .exe files that have .res files embedded in them.
CLICK HERE FOR DOWNLOAD AND MORE INFO
InformationTo avoid having to download a "setup" file asking you to install crap-ware, press "cancel" on the download page, scroll to the bottom to download the .zip file which contains the stand-alone program:
Attachment 69898Last edited by 2635599; December 25th, 2016 at 10:49 AM.
By YourNumbr1Fan in forum Icon appsReplies: 4Last Post: April 18th, 2015, 12:22 AM -
Windows 7 Aero Blur Tweaker by kishan bagaria
By razorsedge in forum DesktopReplies: 2Last Post: February 22nd, 2012, 07:59 AM -
Windows 7 Tray Icons Changer by Kishan Bagaria
By razorsedge in forum Icon appsReplies: 1Last Post: May 19th, 2011, 03:42 AM -
DreamScene Activator by Kishan Bagaria
By razorsedge in forum MiscellaneousReplies: 3Last Post: January 12th, 2011, 11:37 AM -
Windows Application Blocker by Kishan Bagaria
By razorsedge in forum MiscellaneousReplies: 0Last Post: August 9th, 2010, 04:58 AM
Post Your Windows 11...
