June 3rd, 2015 08:25 PM #1
- Jul 2011
- Nowhere
- 947
- 10 Thread(s)
Create Windows 10 .iso After July 29th Upgrade
Thanks to Microsoft Community 'MVP' Andre Da Costa's post here, I thought I would re-post the technique he outlined concerning how to create a full Windows 10 .iso from the .ESD that can be found in the C:\Recovery image folder (your location for this file may be different, depending on the drive-letter Windows is installed on) after the July 29th upgrade. Very useful for those who might want to do a clean-install of Windows 10, and for recovery/re-install. This knowledge may be old-hat to some of you uber-techies, but will surely be helpful to many others.
Without further ado, here's the method to creating a Windows 10 .iso using the .ESD that'll be placed on your hard-drive after the upgrade.
Download ESD Decrypter 4.7
You can use NTLite as an alternative to convert the .ESD file into a .ISO
Extract esd-decrypter-wimlib-4.7z to a folder.
Attachment 70248
Put the appropriate .ESD file you downloaded into that same folder.
Right click decrypt file in the same folder and click Run as administrator
Attachment 70249
Select option 1
Hit Enter
Wait
When complete, burn to a blank DVD or create a bootable copy on a USB thumbdrive.
Preparing the .ISO file for installation.
See these instructions for burning .ISO files in Windows 7 or later
You can also use the Microsoft USB/DVD Tool, which is recommended for Windows XP users.
After obtaining the .iso file you use the Microsoft .iso to USB/DVD tool to create a bootable DVD or USB (requires a blank DVD or USB flash stick of at least 4 GB).
Attachment 70250
For UEFI based systems
If your computer is UEFI based, these are normally systems that come pre-loaded with Windows 8 or later, you will need to prepare the ISO file for such a configuration or you will receive an error message during setup. The thumbdrive needs to be formatted as FAT32 and use the GPT partitioning scheme. To do this, you need to use Rufus, a small tool you can download for free.
Attachment 70251
After you have installed Rufus:
Launch it
Select ISO Image
Point to the Windows 10 ISO file
Check off Create a bootable disk using
Select GPT partitioning for EUFI firmware as the Partition scheme
Choose FAT32 NOT NTFS as the File system
Make sure your USB thumbdrive in the Device list box
Click Start
Close when complete
* Concerning license-key for non-OEM installs/upgrades (as far as I can gather from official sources):
You start with a valid licensed copy of Windows 7 or Windows 8 on your computer.
You upgrade to Windows 10 either by Windows Update or by offline ISO.
At this point, the ID of your computer, the one that Windows normally uses for activation, is registered on the Microsoft activation system. They know from this point forward that your computer, with that ID, is allowed to run a copy of Windows 10
If you want a clean install at this point, you can simply boot from the ISO, erase what you already have there and install. The activation will happen automatically since the ID of your computer is already registered as a valid Windows 10 computer. No need for a key.
And since the ID of your computer is registered as a valid Windows 10 computer, you can reinstall even after the offer expires. The only important thing is to upgrade during the 1 year free offer so that your computer is ID'd.Last edited by YourNumbr1Fan; June 4th, 2015 at 06:12 AM.
Windows 10 20h1 July 2020 update 2004 OS build 19041.388 x32 x64 free Download ISO
By ミறѳѳղղįզվદ彡 in forum Moonnique's Ported ThemesReplies: 5Last Post: August 1st, 2020, 04:19 PM -
Windows 10 Available for Free After July 29, 2016
By Shemhamforash in forum General DiscussionReplies: 1Last Post: September 21st, 2016, 03:45 PM -
Question about Windows 10 build updates/upgrades after July 29th, 2016
By Nimbi in forum Windows rumors and upcoming releases.Replies: 7Last Post: July 14th, 2016, 04:25 AM -
GeForce.com To Stream The Live GSPA Finals On September 29th
By Feed Monkey in forum GeForce.comReplies: 0Last Post: September 15th, 2011, 06:33 PM -
Microsoft to end support for Windows Vista SP1 on on July 12
By razorsedge in forum News & ReviewsReplies: 0Last Post: March 1st, 2011, 11:33 PM
ROG Tweak Theme for...
