Results 97 to 102 of 548
07-31-2015 #1
- Age
- 40
- 5,237
- 739 Thread(s)
Windows 10 Black Edition For Win 10 10240 Only
Update September 19th 2015:
- Fixed crashes
http://www.askvg.com/tip-remove-6-ex...lorer-this-pc/
http://media.askvg.com/downloads/201...10-This-PC.zip
SiB (StartIsBack)
SiB++ Windows 10 v1.0.3
UxStyle
StartIsBack ++1.2
http://startisback.com/StartIsBackPlusPlus_setup.exe
- Minor changes:
AeroGlass-w8.1-1.4.exe
DWM Black Color.reg
Theme Signature Bypass.exe
WinAero Tweaker v3.0.2
I take no responsibility for anyone who bricks their system, Use these mods at your own risk!!Last edited by Mr GRiM; 12-21-2015 at 09:53 PM.
08-04-2015 #97
- Aug 2014
- Coolidge, AZ USA
- Age
- 29
- 1,359
- 55 Thread(s)
For those interested, Check out the Official PhantomDEV Discord
PhantomDEV | Discord
08-04-2015 #98
- Aug 2011
- Olney Illinois
- 819
- 531 Thread(s)
Going back a few posts on what Mark said.... I had the same problem with Uxstyle not changing themes after changing a few times.. although i never tried rebooting.. i uninstalled Uxstyle and reinstalled it everytime it messed up.... it was a nuisance but not that bad. I guess my point is since Uxstlye does work without messing things up it may be smart to stick with it for now.
08-04-2015 #99
- Nov 2010
- Age
- 54
- 3,065
- 451 Thread(s)
o.k. boyz and girlz 10 installed, themed, and looking good. items used in order.
uxstyle 0.2.4.2 win 10 preview
theme signature bypass
startisback cause i decided there was just too much i use missing
oldnewecplorer
classic appearance settings for desktop cascade rightclick
remove all folders in pc reg file
the orginal windows black edition theme / version 2 doesn't want to work
sound packager 1.30.0.0 using the metroid sound pack
clover tabbed explorer
will post a couple of screens later.
08-05-2015 #100
- Aug 2011
- Atlanta, Georgia
- Age
- 54
- 1,195
- 2 Post(s)
- 253 Thread(s)
Are you taling about the registry hack for UxThemeSignatureBypass itself or the reg hack to get rid of white areas?
The reg hack for UxThemeSignatureBypass was written for 10 and tested on it so I don't see how it messed anything up for you, as for the reg hack to get rid of the white areas, that was from 8.1 but I have both installed and both work fine for me.
Did you manually insert the code or did you use the .reg files supplied by Grim and if so, you did right click on the .reg files and select "merge" correct?Last edited by Dark Knight; 08-05-2015 at 05:54 PM.
Visit My Deviant Art Page : http://darkknight2264.deviantart.com/
08-05-2015 #101
- Nov 2010
- Age
- 54
- 3,065
- 451 Thread(s)
Dark Knight what i did in my last post is still working great. the only thing i had to do was uninstall clover. it was causing major problems. if anyone has a app to add tabs to windows explorer that works with 10 please let me know.
08-05-2015 #102
- Aug 2011
- Atlanta, Georgia
- Age
- 54
- 1,195
- 2 Post(s)
- 253 Thread(s)
I wouldn't know bud, I haven't used Clover in quite some time, I tried it way back when it first came out and didn't like it that much so uninstalled it and have been using the native Windows Explorer since.
You might have better luck with the stand alone program Explorer++Last edited by Dark Knight; 08-05-2015 at 05:58 PM.
There are currently 4 users browsing this thread. (0 members and 4 guests)
Dark Windows
By DJ DRIVE in forum Wallpapers Posted by DJ DRIVEReplies: 4Last Post: 08-03-2014, 11:12 AM -
visual style Windows 7 for W8
By blux in forum General Windows 7 CustomizationReplies: 2Last Post: 06-23-2014, 08:18 AM -
Windows 8 Style
By sete in forum Wallpapers Posted by seteReplies: 13Last Post: 12-05-2012, 10:59 AM -
windows seven dark
By bluex in forum Wallpapers by Other Great ArtistsReplies: 4Last Post: 03-11-2012, 01:25 PM
